Results 1 to 13 of 13
    Thanked: 1641
    Default FNB and sent Pin Codes
    Every time I try log onto FNB Banking I wait for a pin message on my mobile, and or never get a pin and or have to request that the resend the pin multiple times. When I finally gain access it is no different, every transaction that require authorising I go through the same dilemma.
    Anyone else with the same.
    Thanked: 1318
    Default Re: FNB and sent Pin Codes
    Sorry, can't help. But, if it's any consolation, be thankful you didn't have to go through the Nedbank "upgrade" in February... it could be worse.
    "The problem with internet quotes is that they are very often unverified."
    -Abraham Lincoln
    Gqeberha
    Thanked: 5024
    Why OTP, don't you now authorise with the app?
    May 2019
    Brackenfell
    Thanked: 244
    https://mybroadband.co.za/news/banki...re-is-why.html
    FNB did away with OTP PIN's a while ago, sort of.
    I assume you don't have the App?
    From what I understand, they will first try and push notify you via the App, if there is no response from the App, or after a certain amount of time they will finally follow up with an SMS/USSD.
    2018 Mitsubishi Pajero Sport 4X4
    2016 Mazda CX-3 2.0 Dynamic Auto - Sold
    2012 VW Tiguan 2.0TDi Bluemotion - Sold
    2009 Ford Fiesta 1.6 Titanium 3 door - Sold
  5. The Following User Says Thank You to WernerDL For This Useful Post:
    Aug 2014
    Yzerfontein
    Thanked: 303
    Quote Originally Posted by WernerDL View Post
    Confirm the above is....they first try to get authorisation via the FNB App...then revert to the OTP via sms if they don't get a response.....
    2006 Defender 90 CSW Td 5
    Nissan Patrol 3 lt V-6 d/c - sold
    Nothing is ever what it seems.....:
    The ''Bitterness of Poor Quality remains long after the Sweetness of Low Price.....''
    Aug 2014
    Yzerfontein
    Thanked: 303
    Confirm the above ....they first try to get authorisation via the FNB App...then revert to the OTP via sms if they don't get a response.....
    Thanked: 1641
    It is the FNB phone App. They send me a message an I enter my pin and the transaction goes ahead. What am I missing?
    Thanked: 3688
    My FNB app allows me to authorize transactions via the app.
    No pin needed.
    ASPW on the Jeep Grand Cherokee: "This vehicle is phenomenal... I have never seen a traction control system working quite like this..."
    Dec 2007
    Thanked: 173
    Quote Originally Posted by Rainier Vermaak View Post
    No pin needed.
    Same here.
    Metalian Maxi
    Thanked: 1641
    I did not mention it was business banking if that makes a difference.
    So how does that work?
    I logon and my phone beeps, and I have to type in my pin. Don't any any means of circumventing this?
    Feb 2019
    Thanked: 247
    No way of going around it unfortunately. FNB is pushing on with getting rid of the OTP. This new way is a safer way of authenticating transactions IMO. Download the app on your phone and register the device with your online banking. From thereon out if you attempt to make any online banking transaction you will be requested to confirm on the app on your phone (you just click approve and if its an unusual payment they may request a pin). You can also make payments from your phone in which case the 2 factor authentication does not apply but they may resort to a OTP on certain transactions. You can also setup biometric (fingerprint) security that will allow you to log in at a touch or authenticate transactions that way.
    The app is quite intuitive so its worth it.
  13. The Following User Says Thank You to ChasingSunsets For This Useful Post:
  14. #12
    Thanked: 1641
    I have the App installed and use it? Perhaps there are limits set in the banking profile which requires all transactions to be authorised. Will check tomorrow.
    Either way, what worked three days ago is sporadically working now.
  15. #13
    Oct 2012
    Thanked: 293
    I have business accounts with Standard, FNB and Nedbank and I am of firm believe that the FNB online portal was designed by 5 5th grader :-(
    That Mighty Amarok
    Swart Tires wat ek self gekoop het
    Pull over wat my ouma gebrei het
    Vensters waar deur ek kan sien
    Engine voor
    Exhaust agter
