Results 1 to 7 of 7
    Oct 2014
    Thanked: 73
    Default Wheels for 2020 Discovery Sport
    A friend has a 2020 Discovery Sport with 235 55 19 mall crawlers. Do 17" wheels fit this vehicle ? If so, can anyone recommend a decent set of 17" alloy wheels and tyres to match?
    Tzaneen
    Thanked: 406
    Default Re: Wheels for 2020 Discovery Sport
    255/55-19 GY Duratracs should do?
    2012 RR TDV8 4.4
    2006 TDV6 SE A/T(Sold)
    2008 FL2 TD4 SE A/T
    1968 Renault 8 Gordini
  3. The Following User Says Thank You to DiscoFrans For This Useful Post:
    Apr 2019
    Thanked: 1870
    Quote Originally Posted by DiscoFrans View Post
    yeah if you want butter sidewalls. Just in the process of buying g 18 rims for my D4 so I can finally be done with those garbage tyres.
  5. The Following 2 Users Say Thank You to heyyahhey For This Useful Post:
    Centurion + Others
    Thanked: 232
    please let me know bout the 18" rims
    Merit before Race - anything else IS Racism.
    Stay Calm, engage low-ratio, keep buggering on - a Landy Man
    Longevity isn't worth dying for,
    May 2010
    Greenstone
    Thanked: 415
    Our Disco Sport has standard 18s and there aren't many tyre options because of the the clearance on the front. It came with 235/60r18s Goodyear which is a shocking tyre, they chipped on my D4 and now they chipping and flaking on her Disco Sport.
    I've looked around and I will keep the the 235s but put the Geolander AT on it. Which is a 107H.
    Discovery Sport 2.0i D
    Defender 90 LE Puma 2.2TDCI
    Defender 110 DC Td5 (life partners)
    Discovery 1 200 Tdi Auto
  8. The Following User Says Thank You to Byron For This Useful Post:
  9. #6
    Oct 2014
    Thanked: 73
    The real issue is the 17" rims - Do they fit ? Can you recommend a set ?
  10. #7
    Tzaneen
    Thanked: 406
    From looking at LR build spec seems that the 18" is the smallest wheel option?
    GY Duratrac.I have them on my RR and family use them on D4.Not as bad as some people make them.Yes the sidewall is not 3 ply like BFG but then they are MUCH better ride and roadholding wise.Depends what you want to use them for.My 2c....
    2012 RR TDV8 4.4
    2008 FL2 TD4 SE A/T
  11. The Following User Says Thank You to DiscoFrans For This Useful Post:
