Results 1 to 5 of 5
    Default RTT on Wildtrak on the back
    Hi guys and girls
    I have a standard 212 Securilid on my Wildtrak. It has two tracks on the side for a roof rack. Is the 212 SecuriLid strong enough to do something like this:
Name:	Front-Runner-Slimline-II-Roll-Top-Load-Bed-Rack-Kit-For-Ford-RANGER-WILDTRAK-2014-Current-krrt01.jpg
    What company does these installations? Does anyone have a rough estimate of how much this would cost?
    What size Roof Top Tent can I fit without removing the sports bar?
    Thanks in advance for your input.
    Ford Ranger Wildtrak 2016
    Triumph Street Triple 675
    BMW R1200 GS Adventure --STOLEN--
    Jeep JK CRD 2.8D 2010 -- SOLD --
    Polokwane
    Thanked: 707
    Default Re: RTT on Wildtrak on the back
    Phone Frontrunner, they should be able to answer most of your questions.
    https://www.frontrunneroutfitters.co...oad-bedrk.html
    Conqueror Courage 2016
    Mar 2021
    Hi there,
    Yes, it can be done, all by Front Runner, and no need to remove/alter/fiddle with the sports hoop.
    I have the 2 x load bars, with 4 x mounting feet/arms which fits into the Securilid "216" roller cover tracks on my van, with the Front Runner 1300mm Width x 1200mm Length (when fully open length = 2400mm) RTT tent.
    It opens sideways on mine, over the LHS/passenger side of the van.
    For current pricing you'd have to call Front Runner, and/or check their www.
    Also, you could save yourself a few (a good few mind you) pennies, by ordering online, having it delivered to your chosen address via courier, and fitting/installing it yourself.
    I fitted the whole lot, together with the roof load bars & awning, in approx 3,5hrs one Sat arvie.
    I fitted it on my own (it is do-able with a good back) but could/would only be easier with some assistance.
    The Front Runner RTT weighs in @ a rather meagre 43kgs.
ID:	607995   Click image for larger version.
ID:	607996   Click image for larger version.
ID:	607997   Click image for larger version.
  4. The Following User Says Thank You to ArabVR46 For This Useful Post:
    Mar 2021
    Edited.
    Jul 2010
    The Vale
    Thanked: 364
    I had the frontrunner tray fitted, as described above works perfectly, the fact that it is behind the cab mostly out of the airflow means less impact on fuel consumption.
    Ranger Wildtrak
    Ex Range Rover Sport 5.0 SC
    Lotus 7 replica racecar.
