Results 1 to 16 of 16
    Thanked: 54
    Default Resolved - indy for Golf GTI Cape Town
    Hi,
    a friend needs to have the timing chain replaced in her 2006 Golf GTI 2.0 .
    The agents ask a small fortune so she needs to consult a reliable independent .
    Cape Town - southern suburbs if poss.
    thanks in advance ,
    Martin
    Oct 2008
    Ridgeworth, Bellville
    Thanked: 7
    Default Re: Help Please - indy for Golf GTI Cape Town
    Contact Ferroli Performance Centre. They specialise in VW products. They've worked on my Golf 2.0 TDI Sportline and Amarok. Honest, reliable and with good rates. They are based in Killarney Gardens - 021 556 6567
    _________
    2011 VW Amarok D/C 4Motion BITDI
    Bushlapa Miskuier - BL1
    2000 Isuzu 280 4x4 DT D/C [SOLD]
  3. The Following 2 Users Say Thank You to juanv For This Useful Post:
    Robertson/ Larissa, Greece
    Thanked: 4584
    I'll second Ferroli's but just keep in mind that replacing that chain is a big job. It won't come cheap no matter who does the job.
  5. The Following User Says Thank You to Francois Theron For This Useful Post:
    Cape Town - RSA
    Thanked: 449
    Ferrolli's will be good, but also pricy. They more of a tuning shop.
    I can recommend Positive Power if you happy to give them a bit of time to do the job (small workshop)
    Can call Anton 082 414 4104.
    Ex - 2005 Cherokee CRD
  7. The Following User Says Thank You to Quiksilver For This Useful Post:
  8. #5
    Jan 2015
    Brackenfell
    Thanked: 162
    Contact Jamiel at http://www.j2auto.co.za/ in ottery.
    Workshop looks a bit dodgey to some, but his work is amazing and specializes in VAG cars.
    He sorted out my Audi when it decided to blow its DSG gearbox at a fraction of the price.
  9. The Following User Says Thank You to franshorn For This Useful Post:
  10. #6
    Thanked: 54
    thanks everyone for the pointers . much obliged
  11. #7
    Thanked: 3758
    Confused much?
    ASPW on the Jeep Grand Cherokee: "This vehicle is phenomenal... I have never seen a traction control system working quite like this..."
  12. #8
    Thanked: 70
    2006 Golf GTi (Golf 5) has toothed belt and not a timing chain.
    Current:
    2019 Kombi Trendline 2.0TDI DSG 103kW
    2017 Toyota Hilux 2.8 GD6 4x4 Auto
    2016 Metalian Maxi
  13. The Following User Says Thank You to GeckoCampers For This Useful Post:
  14. #9
    Thanked: 4584
    Quote Originally Posted by GeckoCampers View Post
    Is it not the EA888 motor?
    I was under the impression in 2.0l form in the GTi they always had a chain. Something new learnt!
  15. #10
    Thanked: 54
    could well be - the agents quote mentioned both which confused me no end
  16. #11
    Thanked: 70
    Nope, the 2 litre chain engines in the Golf were first introduced in Golf 6
    Current:
    2016 Metalian Maxi
  17. #12
    Thanked: 54
    i only have the vin which is AAVZZZ1KZ6U017944 . Perhaps there is a parts lookup site that can identify the engine type ?
    Engine cover says FSI turbo . This guy talks about golf 5 fsi and timing chain but maybe thats not a local model https://youtu.be/KEnOsmgOZrU
  18. #13
    Aug 2017
    Meyerton
    Thanked: 23
    Quote Originally Posted by MartinClem View Post
    Yes, the Golf 5 GTI has both a toothed belt and a timing chain.
    Toothed belt to drive the exhaust camshaft from crankshaft, and at the back of the head (Gearbox side), you will have a cover wherein the timing chain runs, connecting the exhaust camshaft with the inlet camshaft.
    Note that it also has a chain driven oil pump and balancer shaft unit.
ID:	608001Click image for larger version.
ID:	608002Click image for larger version.
    See attached picture and data file
    FYI: Have a look at the engine number on the license disk. VW and Audi engines are easily identifiable by the first 3 letters of the engine number, eg. AXX12345 or BWA12345 etc. Being a GTI, it should be a AXX, BPY or BWA engine.
    Hope this might help a bit
  19. The Following User Says Thank You to Steve141 For This Useful Post:
  20. #14
    Thanked: 54
    thanks for the info, very interesting
  21. #15
    Thanked: 54
    Quote Originally Posted by Steve141 View Post
    its an AXX . That is a seriously good guide . She can understand her engine now . thanks !
  22. The Following User Says Thank You to MartinClem For This Useful Post:
  23. #16
    Aug 2017
    Meyerton
    Thanked: 23
    Only a pleasure!!
