Results 1 to 14 of 14
    Mar 2015
    Question Motorised jockey wheel for boat trailer
    Hi, does anyone where I might buy a motorised jockey wheel to move my boat a 5.2m infanta SRI, about on gravel driveway with slight gradient? Or better ideas perhaps? Tony
    Jan 2015
    Thanked: 540
    Default Re: Motorised jockey wheel for boat trailer
    Quote Originally Posted by AnthonyGL View Post
    There is someone up JHB way that makes them. I have worked on 2 of these units and they are honestly not worth the money spent on them. Far better to make your own. It is not that difficult.
    Basically you need a frame to accommodate a largish battery, place to mount the winch, some bearing carriers, axle, wheels, and some kind of handle.
    You buy a 12V boat winch and remove the cable. You use the shaft the cable was wound around to mount a small sprocket. Mount the bearing carriers under the frame, through which the axle is passed. A larger sprocket is fitted to the axle between the bearing carriers. Fit a hub either side of the axle, and a handle on the opposite side, and you're virtually good to go. Use the controls the winch comes with to drive it.
    Just a note on the wheel. The manufactured ones I mention in the outset have very small wheels, probably 150mm diameter at most. These will not propel your boat, even on a paved surface. The wheels need to be much larger and Quad wheels work well.
    I will try to hunt down some photos of the ones I have worked on. Will give you a basic idea of what is required.
    Guy B. Vergoes Houwens
    2014 LC76 4.5 V8
  3. The Following User Says Thank You to ghouwens For This Useful Post:
    Constantia Kloof
    Thanked: 1834
    Brandt Theunissen
    2007 Mercedes Benz ML500 5.5
    1968 VW Beetle 2276
  5. The Following User Says Thank You to Koebelwagen For This Useful Post:
    Jan 2015
    Thanked: 540
    That will NOT move a 5.2M duck on a gravel surface! That wheel is far too small and will stand spinning in one place until the cows come home.
    2014 LC76 4.5 V8
  7. The Following 2 Users Say Thank You to ghouwens For This Useful Post:
  8. #5
    Jan 2015
    Thanked: 540
    This is the only photo I have unfortunately, but it gives you a rough idea.
    This is the boat the client was wanting to move, on a paved surface.
    And this is how useless it is with little wheels.
    2014 LC76 4.5 V8
  9. #6
    Jan 2015
    Thanked: 540
    This is the basic drive mechanism, from the winch directly to the axle.
    2014 LC76 4.5 V8
  10. #7
    Plett/Paulshof
    Thanked: 1350
    Contact Old Man Africa in KZN.
    Bruce Hunter. 2019 FJ Cruiser, Audi Q5S Tdi, 2019 VW Tiguan 4motion 2.0tsi(work vehicle), Bush Lapa Kewer 2202, Fusion 17 boat-Yamaha FT100hp 4st.
  11. #8
    King Williams Town
    Thanked: 1693
    Just fit a tow hitch to front of vehicle.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  12. The Following 2 Users Say Thank You to hunter26 For This Useful Post:
  13. #9
    Kloof
    Thanked: 736
    Just seen this second hand electric one on facebook.
    Andrew Beuster
    Amarok milk bottle
    "So really , you are not so smart , you are a old Oomie that has to much time on his hands" - Christo Meisenheimer
  14. The Following User Says Thank You to LandyAndy For This Useful Post:
  15. #10
    Thanked: 1579
    Check out the lowrance local website. They have something of this sort but it is very expensive. I would rather just go with a front tow hitch if you can.
  16. The Following User Says Thank You to stephenplumb For This Useful Post:
  17. #11
    Thanked: 520
    My dad recently installed a mover on his caravan, it operates on both the rear wheels and steers by moving the wheels separately. Not sure that this would work on a boat trailer due to the rear of the trailer going into the ocean, but will surely give a lot more traction than pulling on the towbar/jockey wheel. This setup does work very well on pavement and grass and is able to climb moderate curbs and the like.
  18. The Following User Says Thank You to Commander For This Useful Post:
  19. #12
    Feb 2013
    Thanked: 1060
    Front tow hitch on your vehicle, or mount a winch against the wall or in the ground at its parking spot and winch it in to its parking.
    "The problems we have today is because the guys who work for a living are outnumbered by those who vote for a living." - Magnus Heystek
  20. The Following User Says Thank You to bigboy529 For This Useful Post:
  21. #13
    Mar 2015
    Thank you for excellent advice. I will look at alternatives. Tony
  22. #14
    Mar 2015
    Thank you to all for excellent advice. I will design a pulley system and winch it ito place around the corner. I too was afraid teh small motorosed wheel woucl not work. Cheers
