Results 1 to 8 of 8
    Malmesbury
    Thanked: 164
    Default battle of the bulge tyres
    bought these firestone distanations 4x4 tyres newer adition last year and was always happy with them and handled the rightersveld passes well but my concern was always the sidewall cuts on the rounded bulge ,
    the colt has a slide on camper and tyres was on 300 kpa on the rear, but never tried to cut corners and stayed away of the edges of the gravel road ,but if a sharp flat rock catches it, it will cut that bulge big time or am i wrong opinion please .
ID:	607648   Click image for larger version.
    alberto pereira
    Colt clubcab 2.8tdi 4x4 2005
    Ford Fiesta 1.4i (SWAMBO]
    opel corsa 1.7 dti 2006
    Sep 2018
    Not too far from Pofadder
    Thanked: 1147
    Default Re: battle of the bulge tyres
    I had Firestone destinations on my Hardbody , and they went through hell with a smile. tough tires.
    Even without an outright bulge you can get a sidewall cut, it is not only about the bulge.
    Jors Malan
    FJ Cruiser
  3. The Following 3 Users Say Thank You to Bex For This Useful Post:
    Thanked: 1193
    The theory about side wall cuts is the same as a over ripe tomato thats soft. Its difficult to cut it. So your tyres must be relatively soft. That depends on the ratio of the mass of the vehicle vs the tyre size.
    Thanked: 520
    I had Destination muds on my Jeep, it also got used hard off road and I never had a problem. They were very good tires in my opinion. Granted my Jeep was never nearly as heavy as what you are carrying with the camper on the back, but I have nothing but good feedback.
    Thanked: 3757
    Rim width needs to match tyre size. The most common reason fore excessive sidewall buldge
  7. The Following 2 Users Say Thank You to grips For This Useful Post:
    Malmesbury
    Thanked: 164
    nooit daaraan gedink nie, sal kyk vandag.
    alberto pereira
    Ruimsig
    Thanked: 21942
    Construction can also play a part in s/w bulge:
Name:	Base Data Table 2 Rev 1.PNG
ID:	607699   Click image for larger version.
Name:	Correlation Tables 2.PNG
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
    Barberton
    Thanked: 1964
    I bought Goodyear Adventures a year ago. I soon realised that the footprint is quite a bit narrower than the actual tyre body. Then one day I was parked next to another car with identical tyres and those did not have the narrower footprint. The narrower footprint results in a bulge that exposes the lower sidewall quite badly.
    On close inspection I realised I've got the LT spec Goodyears. I was a little disgusted for not shopping with even more care than my already procrastinating style.
    The Goodyear website has me feeling a little better as it indicates that the LT spec tyres have 2 Kevlar layers and 30% more steel than their non-LT spec cousins.
    PS: we did an extensive trip in Nov last year, including the Richtersveld, and there isn't a scratch mark on any of the sidewalls.
