Will not be much just get a tray, I recon less then a cup of oil will leak out
Hi all,
I need to change out the o ring on the oil thermostat housing. The issue is I want to do it in my apartment building underground garage but I don't know how much of an oil spill I can expect once I remove the oil cooler pipe. Anyone have an idea?
1995 300TDi Defender with VGT Turbo (stolen by my son now)
2005 Defender TD5
The only oil that might be an issue is the oil in the oil cooler.
It should not be a lot of oil, but if possible have some blanking plugs nearby to stem the flow.
My guess is about 250-300mL.
Just make sure you buy the correct o-ring. I tried one from my o-ring kit which was slightly thicker and it broke the housing.
