Results 1 to 7 of 7
    Dec 2020
    Kleinmond
    Default HELP! Land Rover wont go into gear
    My 2005 Land Rover Freelander will not go into gear once you start it. If it is off you can merrily play around with the gears but once it starts NOTHING! I checked the transmission oil and all good, actually all necessary liquids are good, battery good. What are the list of probable faults I could work my way through.
    Thanked: 186
    Default Re: HELP! Land Rover wont go into gear
    model might help people offer comment
  3. The Following 2 Users Say Thank You to RossJ For This Useful Post:
    Tzaneen
    Thanked: 406
    Faulty clutch or binding spigot shaft bush.
    2012 RR TDV8 4.4
    2006 TDV6 SE A/T(Sold)
    2008 FL2 TD4 SE A/T
    1968 Renault 8 Gordini
  5. The Following User Says Thank You to DiscoFrans For This Useful Post:
    Dec 2014
    Thanked: 2720
    Is the pedal in any way spongy or not feeling right? If so, it may be your master or slave cylinder, but my money will be that Disco Frans has nailed the cause.
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Jul 2013
    Weskus van Namibia
    Thanked: 113
    Without much detail, it is hard to diagnose, however, I had the same problem on my Discovery 2 manual after a transfer case replacement.
    In my case, it was an incorrect pressure plate fitted. A proper bleed lessened the symptoms, but never really resolved the issue.
    I would hazard a guess and say spigot bush or done for clutch
    My speelding: 2012 VW Amarok 2.0 TDI
    Vrou se speelding: Astra OuPC
    Thanked: 1581
    Quote Originally Posted by CG1976 View Post
    manual or automated?
    Jan 2019
    White River
    Thanked: 50
    Bracket that secures slave cylinder to engine cracks resulting in clutch not releasing completely.
