Results 1 to 2 of 2
    Feb 2021
    Default Bush Lapa Ratel Geyser Cover and Air Conditioner
    Good day.
    I need some valuable advice please.
    If you have installed the 12000 BTU Aircon underneath the front bed (with the split unit between the fridge and the geyser); I take it you need to get a canvas protective cover made for the gas geyser?
    Obviously the side door always (geyser side) need to be open when the air conditioner is in use?? Therefore the geyser needs to be protected from rain, dust etc?
    Am I correct?
    Then, can some Bush Lapa owners confirm whether this type of air conditioner installation is effective?
    Thanks so much
    Feb 2021
    Default Re: Bush Lapa Ratel Geyser Cover and Air Conditioner
    Hi Delmur
    I am awaiting my ratel 4 and also installed aircon. Friend of mine recommeded the aircon he has in his ratel and it works especially at the coast. Will check on cover for geyser.
    Christiaan
