3 weeks ago I purchased a 5 stage wildberry RO system from take-a-lot. Easy to install and is working perfectly.
I have been playing with the idea of adding a filtration system to my camping setup ... caravan with tank ... to manage water issues when on a trip, and now also have the need to set up one in my new kitchen at home.
So, confusion is about stages required for either, with pressure tank or without, and what about booster pump? Plus there is sooooo many suppliers out there... just on Takelot you are bombarded with multiple offerings, and prices vary considerably.
'20 Ford Ranger XLT, Bushtec Canopy
'18 Compass offroad Caravan
2013 Infiniti QX70 3.0D S Premium
2012 Lexus GS 350
1998 BMW Z3
I have the same thing on the drawing board for camping and I am guided by this guy in terms of my thinking getting a 12v UV light might be the challenge. https://www.youtube.com/watch?v=geGO_yNmVKM&t=13s
The issue in an urban setting is chemical and heavy metal contamination which is usually why you would need five stages, although I personally think this is a bit of overkill, but then again I paddle in the murky waters of the Umsinduzi and Umgeni rivers so maybe you can ignore my sentiments here. The assumption in a rural setting is that you are faced with a biological threat and the UV will deal with this, a single stage filtration might not be sufficient but then you simply run the water through multiple times until you are satisfied with the clarity after all you are only dealing with 50-200l. As an overlander with no trailer or caravan I would find a 5 stage filter far too bulky and impractical particularly if it requires a 230v power supply.
An interesting option a R650, 800ml per minute and 30 000 in total https://water-genie.co.za/
Something to note with RO systems or the one we have installed in the house anyway, is that it wastes water, this might be a problem in a overlanding application if you have limited water.
The Little Luxury systems was discussed here on the forum before, they have different options, if I remember a 3, 4 and 5 stage and they are advertised specifically for travel if I remember.
"The problems we have today is because the guys who work for a living are outnumbered by those who vote for a living." - Magnus Heystek
2021 Hilux Raider 2.8 GD-6 4x4 D/C Auto "Luxy"
2018 Baobab 4 - B1543 "Nala"
Bacon fact #16 - Bacon is Healthier than Crystal Meth!
Thanks for sharing.
Also https://www.o3water.co.za/thirst-aid-kit.html
Conqueror Courage 2016
Yip, but they claim RO water leaches minerals from your body. But I would prefer RO water than none, or dirty water.
I kept things simple in my camper - did not want complicated filtration systems which can go wrong. So I have 2 x 9" cartridge filters in line, a 10 micron followed by a 0.1 micron (could be 0.2?). The water is pumped through these before reaching the tanks - I don't believe in carting around unfiltered water. If the water is suspect, as in pumped from a dam or river, I add Miltons to nuke the bacteria.
Then I have another 9" carbon filter in the kitchen to remove bad tastes for cooking and drinking water.
Mike Lauterbach
