Results 1 to 9 of 9
    Apr 2009
    Thanked: 338
    Default Puma 2.4 fuel supply/high pressure line failure.
    Drove 5am this morning and got a heavy diesel smell in the cab of the 130.
    2km further the truck cut out and I was stranded... for the 1st time in 13 years of landy ownership.
    anyway, opened the bonnet and Diesel was sprayed towards the bottom side of the engine where the fuel pump is mounted.
    The diesel return line felt loose, but can obviously not cause the fuel starvation.
    So I suspect the copper seals on either the supply line connection to the pump or the high pressure line connection from the pump to the injector rail..
    the Ultra gauge showed the fuel rail pressure as normal before cut out..
    Anyone had a similar experience?
    D90
    D130
    Thanked: 1265
    Default Re: Puma 2.4 fuel supply/high pressure line failure.
    hectic, hopefully you managed to stop safely.
    Have you also checked the fuel cooler?
    Apr 2009
    Thanked: 338
    yea, was just off the highway and across the fuel station when she died.. slowly coasting to the side.
    Fuel cooler is more on the chassis, the wet diesel was directly around the 2 pump connectors.
    Suspect the supply as the high pressure side is 20bar, then fuel would have been every where..
    I cleaned out the 130 over the weekend and removed the toolbox and more importantly the fire extinguisher ... this could have ended very BAD.
    D90
    D130
    Apr 2009
    Thanked: 338
    Main PITA will be to bleed the damn thing again ... should really look into fitting the secondary filter with manual bleed pump ..
    D90
    D130
    Jan 2015
    Thanked: 12
    I just pressurise the fuel tank via breather to bleed - very little air pressure and flow needed, but make sure line is disconnected at engine side before pressurising...
    1964 SII 88"
    1983 LR90 V8
    1998 Def 90 2.8i (Her's)
    2011 Def 90 Puma
    Apr 2009
    Thanked: 338
    Quote Originally Posted by Blikkie View Post
    heard about that trick before (and dangers of over pressuring) 'will get my Son to Blow into the tank until all air is out' hahaha
    D90
    D130
    Jan 2015
    Thanked: 12
    Be kind.....let him use a bicycle pump!!
    1964 SII 88"
    1983 LR90 V8
    2011 Def 90 Puma
    Jan 2010
    Fourways Gardens
    Thanked: 783
    Any news Dtox?
    Defender Puma Raw Limited Edition
    Series III 88"
    Scout Nomad
    Chop your own firewood and it will warm you twice
    Apr 2009
    Thanked: 338
    Quote Originally Posted by ClaudeG View Post
    Any news Dtox?
    Yes Sorry!
    So it was a hairline crack in the hi-pressure line from the pump to injector rail , right in the bend.
    Very odd place to crack, possibly due to stressing the line previously when someone worked on teh injectors, pump etc..
    2nd hand pipe was R450
    any hoo, going like a Boeing again!
    D90
    D130
  10. The Following User Says Thank You to D-tox For This Useful Post:
