Any recommendations for the best pegs for the
West Coast soft beach sand or does one tie ropes to rocks?
last time round we used tent pegs as per normal and put rock ontop of pegs.
had some of those screw in goodies, did not work for me.
As said above sand bags do work but are quite a lot of effort filling.
Easiest is use a normal tent peg (preferably a long one) with rocks on top. By far the easiest and secure way to do it.
Now if you end up at a place with no rocks well the sandbags esp if submerged will work a treat. (but more labor intensive )
For soft sand I use the anchor pegs. But loooong ones. The sand does get harder the deeper you go, hence the long pegs.
https://www.makro.co.za/sports-outdo...8aAlnSEALw_wcB
The straight ones are useless in sand.
2007 Nissan Pathfinder LE 2.5dCI 4x4
2013 Nissan Xtrail 2.0dCi XE 2x4
Hello,
Some places even the long anchor pegs won't hold in the wind, and there aren't always rocks around.
Agrimark sells perfect size sand bags at a good price. They multitask as part of the Jimny recovery kit although I've not needed them yet. ☺️
Janine
2009 Jimny
Transfer case and Radial cup protection
VPU - rear wheel arches
Packing System & Roofrack
Geolander AT's,
Airbags & EFS shocks
2010 Ford Bantam XLT 1.6 - Sold
1981 Ford Cortina- but it went forever! Until stolen
You can get these anchor pegs from a camping shop. To fit, hook them on and pull on the bottom part causing tension. Hammer the elbow into the ground with a rubber hammer at about 45 deg with tension on until the hook and top is horizontal with the ground. We've camped at St Helena Bay, Swakopmund, Redelinghuys, Biedouw Valley and many sandy places on the West Coast without a problem. The pegs flex with tension but don't pull out:
Pegs marked with arrows:
In sand I use those screw in type, they work a treat. Actually what works best is to screw in the thing, then hammer a peg in against the side closest to the tent. The screwy thing prevents the peg from pulling out.
C
Edit, pic attached
Some excellent suggestions here.
I am wary of that West Coast wind!
Take a plank about 300mm long by 50mm wide by 10mm thick. Tie guy rope around middle of plank. Dig hole into sand, bury tied plank so that flat surface is pulling towards tent ie becomes an anchor.
2x spotlight,2x fog lights
215/80/R15c tyres
1 x great humourous driver
GPS,Bluetooth
Eagle eye dash cam --stolen..bought another one
snorkel soon
Craig
I carry 4 of these with.
https://www.googleadservices.com/pag...gQICRBb&adurl=
Barnie Hickman
Jeep XJ 95 "Witblitz" Jeep XJ 99 "Goldi" Swambo's
Paul, next time you're in town, go into the Cape Bag and Twine factory shop (now just Cape Bag, I think) at 177 Albert Road Woodstock. They sell the bags the roadworks guys use for holding down road signs, cheap as chips, fill them with sand or rocks and they also double up as traction aids in soft sand when partially filled with sand and placed in front of tyres. Besides anything else, the factory shop is full of other useful stuff like cheap duct tape, cable ties, rolls of polyprop rope and cord etc etc.
Tony Weaver
1991 Land Rover 110 Hi-Line S/W 3.5l V8 carburettor
Cooper Discoverer STT tyres, four sleeper Echo rooftop tent
2012 Mitsubishi Outlander.
Previously Land Rover 1968 SII, 1969 SIIA, 1973 SIII, 1983 Toyota HiLux 2litre, 2006 Land Rover Freelander TD4 HSE.
215/80/R15c tyres
GPS,Bluetooth
snorkel soon
Craig
Straight pegs are only used if you have tent floor or instead of roof nails on ground cover. Useless on ropes. Those "L pegs" in correct angle work.
Rubber hammer is useless. I refuse to use such. We have home made steel 1 to 2 kg. That works minus those rock hard grounds where even drill has an issue.
We were 6 weeks on East and West coast. L pegs worked every time. No extra wind ropes, nets - nothing. Xporer has good frame for the "rally". With the road van having rally we had to use wind rope. Always only L shape. It has only 3 upright poles and no frame
There are 2 types of L shape. Post 7 has the straight type. Post 5 has small bend just above the label. Sometimes that bend is substantially more. Those with a bend can be real pain to get to hard ground. We have both types to use
Jouko
2003 Grand Cherokee 4.7l
2012 Smart
Never drive a normal car 8)
Subscribed
This has always worked for us in the past.
When fully inserted the hook to which your rope is attached and the upper part of the "V" peg must be parallel to the ground (Sand) surface.
This helps to avoid tripping over the peg and gives max. grip in the loose sand.
If available rocks or weights of any sort on top would assist.
The longer the lower portion of the "V" relative to the upper, the better.
If really windy (As can be at the coast and some other places in the interior), then a strap across the top of your tent, awning, whatever, anchored by similar pegs should save the day.
However NOTHING is fool proof if the winds is strong enough.
Mother nature will always win.
Peter Hutchison
Platkar = Chevy Spark 1.2
Wrt using a rubber mallet vs steel hammer. I found the rubber mallet bent my tent pegs in hard ground where as the steel hammer sunk those pegs beautifully into hard ground.
The Danforth looking peg is a bloody good idea.
215/80/R15c tyres
GPS,Bluetooth
snorkel soon
Craig
Choose life
