Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 48
    Thanked: 351
    Default My new lathe - Need some advise please?
    Hi,
    So after searching for a decent second hand lathe the past couple of months, I decided to buy a new Chinese lathe...
    I just could not get my hands on a decent Colcester or Emco lathe... Good ones are just not for sale that often...
    Anyway... Yes, Chinese... So I did a lot of research, and my take off was the following:
    If you want to buy Chinese, then buy new. That way you can upgrade the problem areas, and also take good care of it. Most Chinese lathes will be sufficient for light duty use as a DIY machine, thus a new one could possibly outlast you. Most of the 2nd hand Chinese machines was mostly used in a commercial environment, and they are thus in very poor condition. ALSO, the bigger Chinese machines (in other words, NOT bench top) are usually of better build quality as well...
    So, I bought an OLD NEW machine... The machine is new, never been used, but was a display model in a shop since 2013.
    I now have to clean it, drain oils and make sure everything is good before I can start using it...
    It is a Micro-Tech branded machine... 320mm swing x 880mm BC. It is a gap bed lathe (I was actually looking for a non-gap bed). The Chinese number: CQ3236E
    It came with the 3-jaw, 4-jaw, faceplate, 4 additional change gears (only needed for some imperial threads, as most threads are taken care off with the gearbox), MT5 to MT3 bush for spindle, 2 x dead centers, 3 x reverse chuck jaws, follow rest, steady rest and tools... So very complete, as a new machine should be.
    Optional extras also on this machine (I think this is to make it CE approved): Emergency foot brake, Spindle guard, lead-screw cover. It also has the suds tank/pump and a work light.
    First question... How to clean the protective/shipping oil from bed/chucks/tools etc. ?? I've done some research, and most seem to agree that WD40 is the way to go.
    Then, I need some help with oils. I have 2 x manuals, and the one manual suggests:
    Headstock: Shell Turbo T-68
    Feed gearbox: Shell Turbo T-68
    Apron gearbox: Shell Turbo T-68
    Bed ways and oiler balls: 20W machine oil
    The second manual states the following:
    Headstock: ISO 32
    Feed gearbox: ISO 68
    Apron gearbox: ISO 68
    Bed ways: ISO 68
    Oiler balls: ISO 32
    Leadscrews: ISO 68
    Then I have read somewhere on the net that you get "special" way-oil for the bed ways...
    So what is available in South Africa, and what should I use for what?
    I obviously want to drain all oils as the machine has been standing for 7 years...
    Please advise...
    2017 Mitsubishi Triton 2.4 D/C 4X4 Auto Diesel
    Lynx Bashplate
    DIY Drawer system
    DIY Drop Fridge Slide
    My ULTIMATE dual battery box
  2. The Following 3 Users Say Thank You to SinWolf For This Useful Post:
    Thanked: 598
    Default Re: My new lathe - Need some advise please?
    Welcome to the world of lathing! Looks like a good machine.
    Many chips I bestow on you ...
    Oil for my Colchester is as follows:
    Currently available:
    Headstock (ISO classification) - Shell Tellus S2 MX32 - 9 pints / 5 litre
    Gearbox (ISO classification) - Shell Tellus S2 M 68 - 2 pints / 1 litre
    Way oil - Mobil Vactra™ Oil
    To remove the protective oil, simply wash with paraffin. WD40 is way too expensive.
  4. The Following 2 Users Say Thank You to mygoggie For This Useful Post:
  5. #3
    Thanked: 1196
    Parafin or petrol will clean good.
    Thanked: 351
    I'm having difficulty finding these oils in South Africa, and if I do, they come in 20Lt drums
    Lynx Bashplate
    DIY Drawer system
    Thanked: 598
    Quote Originally Posted by SinWolf View Post
    Any industrial lubricant place will supply in 5l containers. This is the way I always buy mine.
    Speak to Rocol Lubricants just round the corner from you.
  8. The Following User Says Thank You to mygoggie For This Useful Post:
  9. #6
    Thanked: 598
    Speseryman ... net nooit petrol nie ... dit blaf! Woof en jy en jou draaibank en jou kwas lyk soos houtskool.
  10. The Following User Says Thank You to mygoggie For This Useful Post:
  11. #7
    Thanked: 1196
    Ek kry self kry hoofpyn van baie petroldampe, maar het groot geword om als met petrol te was.
  12. #8
    Thanked: 351
    Oh... and do I need to somehow try and "flush" the gearboxes with some or other solution? Thanks
    Lynx Bashplate
    DIY Drawer system
  13. #9
    Thanked: 45
    Sinwolf, I was a toolroom turner in my young days and if I can be of help at any time let me know by sending me a pm with your number. I live on the east side of Pretoria.
  14. #10
    Thanked: 351
    Quote Originally Posted by Alansut View Post
    Thanks!! This is a very generous offer!! Especially the fact that you are so close to me!
    I do have other help (the likes of mygoggie and Plunger), but their location is not ideal when it comes to physical interaction.
    I will most definitely contact you if I need assistance... I'm very excited to start working on the lathe, but first things first... need to sort out the cleaning and servicing...
    Lynx Bashplate
    DIY Drawer system
  15. #11
    Thanked: 351
    Another question I missed on my first post...
    Say I strip and clean the chucks... Do I now need to grease the internals? And if so, what grease?
    Lynx Bashplate
    DIY Drawer system
  16. #12
    Thanked: 84
    Here is a very nice video on changing the headstock oil.
    I really like this guys videos.
    Jaco
    Isuzu KB300 DMax D/C 4x4 3" Homemade lift, Bosvark LFR Radio and free-wheel hubs.
  17. #13
    Aug 2019
    Thanked: 261
    The first lesson you will teach yourself when using a lathe is to remove the chuck key from the chuck before starting the lathe.
  18. The Following User Says Thank You to Tiaan Pot For This Useful Post:
  19. #14
    Aug 2019
    Thanked: 261
    Quote Originally Posted by jp_bez View Post
    If i wake up at 2am in the morning I load one of his videos, back to sleep in 5min guaranteed
  20. The Following User Says Thank You to Tiaan Pot For This Useful Post:
  21. #15
    JHB
    Thanked: 208
    Adendorff's sell stuff called spindle oil which they say must be used in the gearbox
  22. #16
    Thanked: 1572
    Actually, never leave the key in the chuck.
  23. The Following User Says Thank You to Peter Connan For This Useful Post:
  24. #17
    durban
    Thanked: 1494
    Congrats . There is a big step up from the small bench lathes to the one you got now. I wouldnt do much in terms of lubricant for the chucks. If its got lube it just turns the oil into lapping paste when it mixes with swarf .
    I dont think its critical what oils you use as long as you are close to what is recommended. I would buy a one oil does it all. There is a company called Germ lubricants where I buy my oil. I use an oil called dynobear 68 . I cant remember if this was for just the ways or if I used it in my headstock as well
    i think I once put in a oil that was for hydraulics that they use for vacuum pumps in the milking industry but Germ are helpful.
    I think for the ways I also used dynobear 68 but they simply added an stiction additive into the oil so it stays on the ways.
    Some oils eat bronze and brass so you need to stay away from that as there are shoes if you can call it that made of phospher bronze that are used for moving the gears back and forth to mesh.
    Germ will also sell you 5 l of oil.
    Its a splash system so the oil needs to be able to get splashed to the top and into the oil reservoirs so that it can lubricate the spindle bearings.
    At least that is how most of these size lathes work. The more expensive lathes like that Monarch are very different .
    Does it have a camlock chuck. ?
  25. #18
    durban
    Thanked: 1494
    I spoke to my mentor and guru and he suggests sae 10 or iso 32 viscosity for the headstock but not motor oil as it has detergents for internal combustion engines which will etch your ways. I think dynobear68 is a way oil suitable for the carriage and gearbox and ways
    I found the container of the first time I did an oil change and I used caltex rando HD 68 a five liter container.It says antiwear hydraulic fluid and milking machine vacuum pump oil.
  26. #19
    Thanked: 351
    Lynx Bashplate
    DIY Drawer system
  27. #20
    Dowerglen
    Thanked: 1116
    congrats on your purchase SinWolf, that is a very nice lathe.
    Never use grease in the chuck, ever.. Strip it if you want to, they are not complex affairs, give it a good cleaning and then a light oil on the moving parts, not too much as as with Plunger’s statement, too much stuff eventually builds into a grinding paste.
    I am rather anal about cleaning my machines, probably to my detriment, but I work better that way, so the chucks I have often get stripped for a deep cleaning, in fact my 3 jaw is starting to bind a little, so here we go again...
    If I may suggest next on your list is a quick change toolpost which you can purchase from Adendorff which includes 4 lathe cutting tool holders, and if you need more, which you eventually will, you can purchase the individual holders from banggood.com..
ID:	607347   Click image for larger version.
ID:	607348   Click image for larger version.
    Regards - Marco Chezzi
    There are two kinds of people in this world, those that can extrapolate from incomplete data..
  28. The Following 3 Users Say Thank You to Marcochezzi For This Useful Post:
