DIY Canopy Kitchen Unit. What material? - Page 2
Results 21 to 34 of 34
    Weskus van Namibia
    Thanked: 66
    Default Re: DIY Canopy Kitchen Unit. What material?
    party keer is dit maar beter om maar net te betaal en dit reg te laat doen. Dit is rede hoekom ek alu boks laat maak het.
    Ja jong, lyk my ek gaan maar 'n metaal werker moet nader om pryse te kry. Ek weier alhoewel om R6000-R10000 vir n brand name boksie te betaal as hy nie outomaties koffie gaan maak ook nie
    My speelding: 2012 VW Amarok 2.0 TDI
    Vrou se speelding: Astra OuPC
  2. The Following User Says Thank You to jeepman85 For This Useful Post:
  3. #22
    Weskus van Namibia
    Thanked: 66
    Its time you expand your circle of friends
    My buurman is n metaalwerker, maar sou gelike het om self die projek te tackel. Ek weet darm nou my gedagte was n poef een.
  4. The Following User Says Thank You to jeepman85 For This Useful Post:
  5. #23
    Nov 2016
    Thanked: 250
    Quote Originally Posted by jeepman85 View Post
    Unfortunately at the west coast of Namibia, this is not an option (that I've heard of)
    Oh bugger......
  6. #24
    Aug 2011
    Brackenfell
    Thanked: 414
    kaal kombuis/utility boks. Ek het onder R1000 betaal vir die boks en insit. Ek het wel self die backing bord, mat en al die ander goed installeer. Alu 2mm dink ek. 450mm breed
  7. #25
    Thanked: 2460
    While aluminium would ideally be the best overall, I just don't possess the skills to make it work like it should
    You were prepared to do it in heavy wood other than the material wat has changed?
    As I mentioned before alu checker plate works well with normal wood working tools. You will need a jigsaw, drill with a 5mm drill bit, pop riveter and a square. Materials you will need rivets(5mm), 1 sheet of alu and a while zoo of rivets with their washers as well as a tube of sika and a length of 25mm alu angle.
    Cut the alu sheet in to the panels you need and assemble with angle and rivets with a good smear of sika.
    Bending the sides and top and bottom panels is first prize but if push comes to shove cutting the bend panels off and fixing with angle can also work. A rattle can of rustoleum will make it look professional. For increased strength you can use a 32mm angle and put it inside and out and space the rivets 100 - 150mm apart, stronger than any heavy timber and less than half the weight.
    Do not be intimidated with aluminium it is a great medium to work with, granted it can be a devil to weld but there are ways to overcome that obstacle.
    Jy moet bang maak nie bang word
    Henk
    Follow us on Facebook
  8. The Following 2 Users Say Thank You to hbannink For This Useful Post:
  9. #26
    Weskus van Namibia
    Thanked: 66
    Van waar? Lyk baie netjies!
  10. #27
    Weskus van Namibia
    Thanked: 66
    Met n groot genoeg hammer kan ek enige iets reg kry, maar ongelukkig is my tyd so klein bietjie beperk. Houtwerk is ek handig mee, metaal, nie so baie nie.
  11. #28
    Aug 2011
    Brackenfell
    Thanked: 414
    Riaan van Rugged Design het my kappie gebou en boks. Ek het die res diy gedoen.
  12. #29
    Weskus van Namibia
    Thanked: 66
    Baie dankie
  13. #30
    Thanked: 430
    Thanks Robbie.
    If I'm building an alu frame, I may as well do the entire thing out of alu, so aluminium angle is what I'm thinking to support to canopy
    Sorry, I was not thinking about a kitchen in a canopy side door aperture.
    Im sure your neighbor will explain how to bend aluminium sheeting and glue it together as per Henks post.
    its basically an angled box with bend on the front for attachment to the canopy.
    good luck, make a template out of cardboard.
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    Sp Tourer
  14. #31
    Weskus van Namibia
    Thanked: 66
    I just got back from pricing 1.4mm aluminum sheets, I now have a doctors bill to pay as well.
    At R790 for a 1200x690 sheet, I'd need 2 which puts the price only R400 below a Rhinoman Utility box (which can apparently be made to work with the Alucab) installed, so looks like that's the route I'm taking. Thanks all for the helpful info
  15. The Following 2 Users Say Thank You to jeepman85 For This Useful Post:
  16. #32
    Jan 2009
    Richards Bay
    Perhaps this video might give you some ideas -
    https://www.youtube.com/watch?v=gXwURQuFAkc
    The square aluminium and corner pieces are available from Maizeys.
  17. #33
    Apr 2008
    For my campervan build I used 9mm Birch ply joined with light aluminum angles - Sikaflexed to the ply and bolted with small 4mm bolts.
    Very easy home construction, light, strong and flexible.
ID:	607751   Click image for larger version.
ID:	607752   Click image for larger version.
ID:	607753   Click image for larger version.
  18. The Following 3 Users Say Thank You to gregjohnson For This Useful Post:
  19. #34
    Feb 2018
    Hey guys. We've got a trip coming up in 2 weeks and I'd like to get a more permanent solution than ammo boxes mounted to my Alucab.
    I browsed the brick and mortar stores, but I refuse to pay 6-10k for a piece of sheet metal/wood, so will try knocking up my own unit.
    What's the prefered material for these? 13mm MDF? Chipboard? Alu? Something else?
    I'd like it to be as light as possible, but not too much hassle (Alu will need to go to an engineering shop) and not fall apart in a year
    Then, what's the best way to mount to the Alucab? Drill out the rivets holding the door frame and attaching the cabinet with brackets to these holes?
    Thanks in advance
    Hi Jeepman85.
    I am in the process of converting my recently acquired VW T4 Caravelle into a camper. There's loads of info on You Tube on how everybody does it. Mine will be different, in that it must be able to convert back to an 8 seater minibus every time I get home. I am therefore obsessed with lightness and would not even consider wood.
    I decided on Aluminium, as I love the stuff and it's dead easy to work with. No welding, no bolts, no rivets. Just stick it all together.
    I have been using a supplier, who cuts, bends and laser cuts to any dimensions I give them drawings for. Nice bunch of guys to deal with too.
    Simplicity was my second consideration, after lightness, so I made sketches of my Camp Kitchen, then broke it down to individual panels, which I emailed my supplier. 4 Days later I had all my panels and I bonded it all together. It was not quite as simple as I have described and if I was to do it again it would be neater second time around.
    I enclose some pics of the almost complete kitchen.Click image for larger version.
Name:	Camp Kitchen 001.jpg
    Struggling with the others, which are on my tablet. Will keep trying.
    The unit is 90cm wide, 33cm deep and 50cm high.
    It has handles on the ends and I can lift it, empty with one finger.
    When making Aluminium boxes for motor vehicles, remember they resonate like a snare drum when driving, which I dampened with self-adhesive pads. It's inside the van, where I can hear it.
    The kitchen unit will be secured to the floor with straps and can pull out of the rear door and rest on the bumper and it's own fold out legs. Can cook outside, or inside if the weather is iffy.
    Will send more pics when I figure out how.
    Pete.
Name:	Camp Kitchen 002.jpg
ID:	607813   Click image for larger version.
Name:	Camp Kitchen 003.jpg
  20. The Following User Says Thank You to Jeep Cherokee For This Useful Post:
