Results 21 to 31 of 31
    May 2014
    Tshwanetoria
    Thanked: 4507
    Default Re: pinnacle welder?
    Long shot Rymar Gas and Hardware in East Lynne, Pta
  2. The Following User Says Thank You to hatjohan For This Useful Post:
  3. #22
    Jul 2008
    Constantia Kloof
    Thanked: 4476
    Quote Originally Posted by Searcher View Post
    Koebelwagen
    It's worth mentioning that these pressure cylinders need to be pressure tested and inspected every 10 years.
    If they are not current, they will need be sent away for pressure testing and certification.
    The pressure testing is not expensive and can be done (sent away) by your local fire extinguisher service center for the tests.
    So just be aware of this when buying a used cylinder, as if may not be current and may not pass the pressure test and inspection.
    These dates are usually punch stamped onto the cylinder around the shoulder/neck area.
    Thanks for this. I got a quote for a filled Air Liquide cylinder and they also refill at reasonable cost.
    Are you going to use co2 for the gas. ?
    Yes, CO2 welding gas.
    I do, works well for MIG welding.
    It's also one of the selectable settings on the Migarc 200.
    Attachment 742826
    Yes, quite a nice little machine.
    Brandt Theunissen
    2024 Isuzu D-MAX 3.0 DDI LSE 4X4 A/T E/CAB
    2007 Mercedes Benz ML500 5.5
    1968 VW Beetle 2276
  4. The Following User Says Thank You to Koebelwagen For This Useful Post:
  5. #23
    May 2011
    Thanked: 4854
    Koebelwagen
    There is some Migarc 200 info here on the 4x4 CF in the last link below that you may find useful, I will repost some of the info here again for completeness.
    I have also attached the MIGARC 200 pdf user manual and a pdf with some of my settings that work for me.
    I compiled the list of settings from numerous sources and some practical testing. The settings are general, there is a lot of latitude as the welder is quite forgiving.
    I weld with CO2 as shielding gas.
    This link guide was sent to me by Pinnacle: https://www.pinnacleonline.co.za/blo...s-and-settings
    More info here on 4x4 CF:https://www.4x4community.co.za/forum...28#post5096528
    Cheers Searcher
    Attached Files Attached Files
    Land Cruiser 100 Series Sahara 4.2 TD
    Land Cruiser 200 Series VX V8 2UZ-FE
  6. The Following 2 Users Say Thank You to Searcher For This Useful Post:
  7. #24
    Jul 2008
    Constantia Kloof
    Thanked: 4476
    Thank you very much!
    Brandt Theunissen
    1968 VW Beetle 2276
  8. #25
    Postmasburg
    Thanked: 1372
    Why would you buy AcrylSpeed or Terryl instaed od CO2?
  9. #26
    Nov 2017
    Thanked: 545
    Quote Originally Posted by Mapog View Post
    if I remember correctly -
    Teryl gas is more forgiving, giving a nicer arc with argon and is easier to weld thin steels. Less distortion when welding. Think its for less than 4/5 mm
    Co2 gives more penetration, more spatter but with a welder with slope and other settings can match teryl.
    Everything should be made as simple as possible, but no simpler.
  10. #27
    Postmasburg
    Thanked: 1372
    I “bought” a air liquid bottle from a gas supplier bussiness for R2000 about 4 years ago.
    They always filled it up for me(exchanged).
    Short while back they said that they not gonna fill the bottles they sold me anymore, but I must now take my bottle back to them,….they will give me two months rent free(R500) and then I gotta start paying a monthly rent.
    Needles to say what I told them…
    But I have a bottle,…..but can I make any claim to it. I didnt sighn for it? I just gotta keep on filling it somewhere.
    Is it possible to buy these bottles. Lost of these gas retailers want to buy it from me. I guess they have more stock(bottles) on hand than what Air liquid is aware of and now they want to rent them out on the sideline……
  11. #28
    Dec 2009
    Thanked: 389
    There was a discussion on FB regarding the cylinder issue and seems partly to blame on the safety aspect of these going out of date. If I can buy and refill a diving cylinder rated at 300 bar, keeping up with test and inspection, why not for any other cylinder?
    I really want a shielding gas of sorts and would like to have small cylinder. With the amount of welding I do it would take years to finish a large cylinder all whilst having to schlep it all over the place.
  12. #29
    Thanked: 5867
    Divers use argon for drysuit fills but these are the rare tek divers. If anything, Peter Herbst at reef divers PTA can point you into the right direction for a tank.
    He can also organize hydro tests and inspections
  13. #30
    Thanked: 2466
    Those cylinders are never for sale. You rent them. So you should take it for a refill and they should only refill if you have an account. But nobody by us does. The just swop.
    Angel Group
    Solar-Construction-Offroad
    [email protected]
    0824453301
    Next event: 4x4 Recovery-TBA
  14. The Following User Says Thank You to Engel For This Useful Post:
  15. #31
    Thanked: 4775
    Correct the cylinder is never sold, the quote is probably for a deposit on the cylinder.
    Air Liquide is the one to go for, Afrox is full of it.
    Brandt there is a air liquide outlet in Honneydew, Instruweld, no issues and have a full range if wire and other consumables at not bad prices
    Henk
    Follow us on Facebook
  16. The Following 2 Users Say Thank You to hbannink For This Useful Post:
