Results 1 to 5 of 5
    May 2019
    Kensington
    Default 280 DT Wheel bearings - 1999
    Hello All
    Does anyone have the Technical specs for the Front Wheel bearings for the Isuzu 280 dt 4 x 4 year 1999. The manual does not show it
    I need to replace it urgently
    thanks
    Mark
    Friemersheim, Southern Cape
    Thanked: 4396
    Default Re: 280 DT Wheel bearings - 1999
    Not sure if this is the same hub and bearing? Might help
    https://www.4x4community.co.za/forum...Wheel-Bearings
    '98 Daihatsu Rocky 'The Kitty'
    '02 Daihatsu Rocky 'The Bully'
    Apr 2018
    RSA
    Thanked: 1859
    Quote Originally Posted by MarkDaniels View Post
    Hello All
    thanks
    Mark
    Which specs? I have the torque and preload specs.
    King Williams Town
    Thanked: 1690
    Best advice is remove the outer and inner bearings, take to agents or bearing man and get replacements. Nothing more frustrating then starting a job only to find bakkie bearings purchased are for previous model for example and don't fit.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  5. The Following User Says Thank You to hunter26 For This Useful Post:
    Sep 2019
    Kokstad
    Thanked: 39
    Front inner wheel bearing has a chamfer on it so it locates correctly on the stub axle. A lot/almost all of the bearings supplied by the likes of Midas donít have this chamfer. Agents want around R650 a bearing ... Just a side note - the current 6th Generation 4x4s still use the same wheel bearings, needle roller bearings and knuckle/wheel bearing seals as your bakkie.
