Results 1 to 11 of 11
    Apr 2014
    Thanked: 135
    Default Draad span / Fencing
    I have 2.5mm fencing wire and for explanation purposes let's say game fencing.
    Quick question/s:
    1) Do you start at the top or at the bottom? My logic tells me at the top.
    2) What tension do I put on the wire? I have one of those Obaro pullers with a tension scale.
    Pretoria, Hartbeesfontein
    Thanked: 1001
    Default Re: Draad span / Fencing
    Yes start from the top, make sure your poles are well set in the soil. My worker don't use a tension scale, he knows from experience what the tension must be
    Robert
    '09 VW Caddy Maxi TDi
    '06 Citroen C3 1.4HDi8)
    '97 Isuzu 280 S/C plaasbakkie
  3. The Following User Says Thank You to Tweeling For This Useful Post:
    Apr 2014
    Thanked: 135
    So, first thing this morning I had to make myself a "spinning jenny". Click image for larger version.
    Apr 2014
    Thanked: 135
    All poles only planted and compacted with stone/rocks and sand. Luckily I have enough rocks. If the fence is not laying on the floor after a week I have saved a whole lot of money not using concrete. Click image for larger version.
ID:	607594Click image for larger version.
ID:	607595Click image for larger version.
    R
    Friemersheim, Southern Cape
    Thanked: 4413
    Quote Originally Posted by LdLL View Post
    All poles only planted and compacted with stone/rocks and sand. Luckily I have enough rocks. If the fence is not laying on the floor after a week I habe saved a whole lit if money not using concrete.
    My poles & fence is still standing upright after 10yrs using same method. Even on slopes
    Even my house...the four corner posts have concrete, the 41 other ones are all stone and soil compacted
    '98 Daihatsu Rocky 'The Kitty'
    '02 Daihatsu Rocky 'The Bully'
  7. The Following User Says Thank You to Prof For This Useful Post:
    Thanked: 218
    Nice work there! My dad always said: Goeie buurmanskap begin by 'n ordentlike lyndraad! Good neighbourliness start at a decent boundary fence!
    Heard this one about putting up a fence for goats:
    Plant all poles and anchor posts. 'Span' a wire every 3 inches (OK 75mm), and tension wires as you span them.
    Once you've reached the top of the poles, start at the bottom again, and space wires 3 inches apart (that means you've now got a wire running every 35 mm)
    Repeat this until you've run out of wire.. Now take a break, and get a bucket of water.
    After the break, slosh the bucket of water through the fence.
    If any water gets through to the other side of the fence, there's not enough wire strands on your fence to keep goats out (or in)..
    Thys de Wet
    Jimny 2009
    Ek het nou klaar gewerk, maar ek weet nie of die bank daarvan gaan hou nie...
  9. The Following 3 Users Say Thank You to dewets For This Useful Post:
  10. #7
    Apr 2014
    Thanked: 135
    Quote Originally Posted by dewets View Post
  11. #8
    Robertson/ Larissa, Greece
    Thanked: 4626
    As someone who spent many a day starting as a toddler with my dad putting up fences, I can tell you that is a very neat piece of work! Although quite expensive. The bottom section probably would have been cheaper using " jackal proof" fence, but I would have no idea of fence cost now to be honest.
    Hard work for sure!
  12. #9
    Apr 2014
    Thanked: 135
    Thanks Francois
    Hard work indeed. It is more of a test run, because I want to fence off a "kraal". My son and I are talking about getting a few cattle (a bull and two cows) for a start.
    Hard work for sure!
  13. #10
    Jan 2020
    Thanked: 112
    This type of farm fence is fairly simple. When you have to put up an electric fence that has 20 to24 strands then you need some manpower. Been there done it got the T shirt.
  14. #11
    Thanked: 2837
