Page 2 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 ... LastLast
Results 21 to 40 of 367
    Thanked: 7158
    Default Re: March Difflock vs Traction Control brekkie Run
    Quote Originally Posted by Bogaards View Post
    I suppose the only problem with Hennops is that you can do most of it without DL by choosing the correct line (I guided 2 previous Gen Jimnys through as well as a Prado which only had a LSD). Therefore you will most likely not be able to test the effect of a front locker.
    Rear DL will idle through everything. TC will work like TC should with a bit more wheelspin.
    The standard Amarok with road tyres will do everything. Guided a 4x2 Auto Amarok through most of the track.
    What you will typically need are some serious uphill axle twister where you need good traction and where one wheel pulling/pushing (In Low Range) will not be enough. Should also be such that it cannot be overcome by good flex.
    Valid points Henk, but to find the right place in all aspects of the theory on this type of test will be difficult... and then to keep it close enough to have enough attendance to make it fun for all, is an added challenge.
    We endeavour to do the test as good as possible taking the track and conditions into account...
    And... have fun, and be social as the brekkie runs are supposed to be
    Andrew van Staden
    I drive a fire engine red Cruiser and tow an army inspired van.
  2. The Following 2 Users Say Thank You to Hedgehog For This Useful Post:
  3. #22
    Mar 2007
    Thanked: 328
    I'm in.
    Do I bring Evoque or New Defender?
  4. The Following 2 Users Say Thank You to shady For This Useful Post:
  5. #23
    Apr 2012
    Thanked: 257
    Quote Originally Posted by shady View Post
    I'm in.
    Both
    But if I had a choice, although hugely advantageous, the new defender will be awesome to see in action.
    RechardT
    Now- Toyo GD6 2.8- Creed
    One day is One day- Dodge Ram 6.7l TD.
    You can go anywhere you want in life as long as its in a 4x4.
  6. The Following User Says Thank You to rechardt For This Useful Post:
  7. #24
    Mar 2007
    Thanked: 328
    Quote Originally Posted by rechardt View Post
    Both
    I'll chat to the wife...
    Stranger things have happened
    If there's a Landcruiser going, I'll just bring the Evoque though. Proven to pull out Landcruisers safely
ID:	605885   Click image for larger version.
Name:	Screenshot_20210207-204736_Video Player.jpg
  8. The Following 2 Users Say Thank You to shady For This Useful Post:
  9. #25
    Putzonderwater
    Thanked: 989
    Ummm...
    Guys, it seems I started something exciting with a sense of 4X4 camaraderie in the air ie it is not a brand competition (Which is absolutely wonderful).
    But, I live in PE, how am I going to get to Hennops on 7 March No worries, have fun and I am very excited to see the results and feedback.
  10. The Following User Says Thank You to HeinrichC For This Useful Post:
  11. #26
    Ruimsig
    Thanked: 24275
    Since I did KoosseklimseAtsegat at De Wildt in 4H with fully inflated AW tyres the other day I think I will spectate and do brekkie only
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
  12. The Following User Says Thank You to Estee For This Useful Post:
  13. #27
    Nov 2012
    Thanked: 1488
    I see I was added by default...I wonder why...
    Looking forward to it.
    Choose life
  14. The Following User Says Thank You to Coenoes For This Useful Post:
  15. #28
    Apr 2012
    Thanked: 257
    So modest....You mean you did Gert se klippie with kaput shock absorbers...tell them..
    RechardT
  16. The Following User Says Thank You to rechardt For This Useful Post:
  17. #29
    Ruimsig
    Thanked: 24275
    ..... and All Weather tyres at 2.7bar :-)
    Hummer H3 V8
    W.A.P Objectivist
  18. #30
    Aug 2011
    JHB
    Thanked: 207
    Would be fun, unfortunately not available that weekend.
  19. #31
    Dec 2020
    Thanked: 6
    I have a stock 2019 Duster 4x4, I'll bring it along!
  20. The Following User Says Thank You to Rammies For This Useful Post:
  21. #32
    Dec 2019
    Thanked: 58
    Can i bring the XC90 with the RT tyres? Might be interesting to see how a softroader with a rather mediocre offroad system works with the angriest tyres you can find that will fit on it haha
  22. The Following User Says Thank You to XC90 For This Useful Post:
  23. #33
    Oct 2018
    Magaliesig
    Thanked: 697
    Will a soft roader amarok be permitted? I have no plans to break the wagon and will cop out if it gets too hairy and testosterone filled.
    Sentiments echoed. Must be an Amarok thing...
    Rob Kirk
    Amarok V6.
    Sym 200 scooter 2 x 1, CVT transmission, 4V OHC, 11.4 kW, 15NM
    0-60km/h in about 10s (downhill), Top speed - 100km/h (on a steeper downhill)
    Ground clearance : 125mm on 16-inch rims
    Tare : 134kg, GVM : 250kg (approx), GCM : 250kg (approx), Towing capacity : 0kg
    Best of all : 4L/100km, town driving and pinning it...
  24. The Following User Says Thank You to Ama-newbie For This Useful Post:
  25. #34
    Apr 2012
    Thanked: 257
    Quote Originally Posted by XC90 View Post
    Yes please..
    RechardT
  26. #35
    Sep 2020
    Please count me in. Anyone know someone who's got a Subaru with X-mode? I'd like to see how it compares to the previous generation like mine.
    Jacobus Jonker
    2017, Subaru, ......, Red
    2015, Subaru, XV, Orange (Current)
    2001, Subaru, Forester, Silver (Retired)
  27. The Following User Says Thank You to Kleinbok For This Useful Post:
  28. #36
    May 2014
    B-gowrie Randburg
    Thanked: 391
    ... my money would be on double diff lock vehicles.
    Single diff-lock vs traction control over 4 wheels not a fair test.
    ... then there’s crawlers ....
    2002 Defender 130 DC HCPU. :
    Own the road... Any road ...
    ‘1981 R-Rvr Classic 2-Dr 3.5L V8 :
    The Greatest Rover.
    ‘1975 Series3 88 PUP :
    Simply ... Classic ...
    ‘2017 Metalian Mini ...
    A Home from Home
  29. #37
    Thanked: 1760
    I recall some nice axle twisters right at the first hill. Yes you can go around them, but you can also go straight through if you want to test things a little more.
  30. The Following User Says Thank You to stephenplumb For This Useful Post:
  31. #38
    Thanked: 1760
    So i have locked the event into stone with an invite sent to the madams calender and mine so that I don't forget. Look forward to meeting some of the good folk on this forum. I shall be in the one galloping in front of the amarok guiding the madam through the obstacles. I shall bring a camera to try and record some of the fun, but last time i did this I realised my camerawork was pretty poorly to put it mildly.
  32. The Following 3 Users Say Thank You to stephenplumb For This Useful Post:
  33. #39
    Apr 2012
    Thanked: 257
    Quote Originally Posted by Kleinbok View Post
    Awesome, added
    RechardT
  34. #40
    Apr 2012
    Thanked: 257
    Quote Originally Posted by BushNomad View Post
    Come prove it...
    RechardT
