Page 8 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 ... LastLast
Results 141 to 160 of 367
  1. #141
    Mar 2007
    Thanked: 437
    Default Re: March Difflock vs Traction Control brekkie Run
    Attached Files Attached Files
  2. #142
    Mar 2007
    Thanked: 437
    I suspect confusion....
    See Hedgehog's Ford Ranger - Centre Difflock = no
    (I suspect this is because it isn't actually a difflock per sé. It just sends 50% power forward and 50% rearward when it's put into 4x4, right?)
    Now see Fortuner and the Amarok - Centre Difflock = yes.
    Have they not got pretty much the same setup?
    Seeking clarification....
  3. #143
    Oct 2017
    Rustenburg
    Thanked: 8649
    Default March Difflock vs Traction Control brekkie Run
    Quote Originally Posted by shady View Post
    The previous gen Tuner was full time 4 x4
    So is the Amarok
    But that Fortuner does not have a center diff, so it cannot claim a diff lock
    We shall clarify at venue
    Andrew van Staden
    FJ - 2 Batteries, a tow bar, OME, Adventurers, and a drawer
    Ex:
    Ranger 3.2, LC 76 V8, Navara 2.5, NP300, Patrol 4.8, Everest 3.0, Jimny 1.3, Defender 110 SW Puma
  4. The Following User Says Thank You to Hedgehog For This Useful Post:
  5. #144
    Thanked: 493
    As far as i understand when you change from 2H to 4H then the center diff is engaged to share power from back to front equally for driving on dirt road for better tracktion.. 4L from there then etc.
    When you back to tar 2H it is dis- engaged
    Riku W3ss3ls
    2011 Echo4 with Blinkgat Nose cone and
  6. #145
    Oct 2017
    Rustenburg
    Thanked: 8649
    Quote Originally Posted by zeek View Post
    There is no center diff in a part time 4x4, The transfer case connects the two axles directly. That is why you get windup on hard surfaces with a part time 4x4 that is in 4x4 (Low or Hi)
    Andrew van Staden
    Ex:
  7. #146
    Thanked: 493
    Yes is what i am talking about. So not sure if the word center diff should be on the options there as will be confusing
    Riku W3ss3ls
  8. #147
    Oct 2017
    Rustenburg
    Thanked: 8649
    Rather the option should be marked not applicable by the owners of part time 4x4 system
    Andrew van Staden
    Ex:
  9. #148
    Oct 2018
    Magaliesig
    Thanked: 736
    Will sort out on the day. For now I just want to fill in (most of) the columns to save time at registration...
    Rob Kirk
    Amarok V6.
  10. #149
    Oct 2018
    Magaliesig
    Thanked: 736
    Updated
    Rob Kirk
    Amarok V6.
  11. #150
    Ruimsig
    Thanked: 28562
    The LRs and the H3 are full time 4x4. The centre diff acts the same as it does on an axel except it allows different rotation between front and rear as opposed to left and right. I can lock this in 4L. But it is also subject to wind up.
    The confusion is arising from the term diff as opposed to a coupling, which a number of new vehicles have, like some of the modern bakkies which are rear wheel driven. When 4x4 is engaged, the coupling ''locks'' front and rear prop shafts but dont have the ability to slip, hence the wind up. It, therefore, is not a diff (allowing for differential rotational speeds between front and rear)
    However, to compound the issue, there are viscous couplings used on some AWD vehicles. This allows the vehicle to be in 2 wheel drive but automatically ''locks'' front to rear when traction decreases or, it can be locked manually. The Jeep Patriot has such a system.
    In short, a CDL will allow slip front and rear if not locked whereas a ''coupling'' will not and is purely a means to lock front and rear. Such vehicles, like the Amarok, do not have a CDL in the true sense, but they have a coupling that will lock F to R when selected.
    I hope that helps in clarifying the issue
    Estee = S T = Sean Towlson
    Hummer H3 V8
    #itsnotaboutME
  12. The Following User Says Thank You to Estee For This Useful Post:
  13. #151
    Ruimsig
    Thanked: 28562
    Gents, I will not be able to attend this event. A lack of comms between me and the First Wife have resulted in a double booking and in order to keep the peace..................................
    Hummer H3 V8
    #itsnotaboutME
  14. #152
    Kathu
    Thanked: 4323
    Quote Originally Posted by Ama-newbie View Post
    Updated
    Only one vehicle with double lockers. Wens dit was nader.
  15. #153
    Thanked: 5945
    And no Amarok 4Motion. Would love to have seen one in that company
    Gert Grobler
    VW Touareg V6 Tdi Escape; Land Cruiser 105
    Bush Lapa Boskriek 816
  16. #154
    May 2015
    Thanked: 73
    Guys please update the coulorful sheet.
    my info attached.
    Excited about tomorrow.
    Peet Rademeyer
    2021 Toyota Hulix Xcab 4x4
    2006 Land Rover Discovery 3 V8SE
    2007 SOLD Mercedes Vito 115CDI
    1998 Sold - Kia Sportage 4x4 Gen1
    2003 Sold - Mazda 2.5 DC 4x4
    1996 Sold - Isuzu 2.8 DT Reef
    2008 BMW F800GS
    2006 Renault Modus 1.6 Auto (student car)
    2013 Hyundai i20 (Swambo's car)
    2014 Honda CBR125r (Boy's racer)
    2003 Jonway 125 (Girls racer)
  17. The Following User Says Thank You to GreenZone For This Useful Post:
  18. #155
    Thanked: 493
    Hello. Sorry ouens but have to cancel tomorrow. Couple of things came together and best not to go.
    Enjoy they day there
    Riku W3ss3ls
  19. The Following User Says Thank You to zeek For This Useful Post:
  20. #156
    Pta
    Thanked: 133
    My H3 will still be there!!
  21. The Following User Says Thank You to renier_c For This Useful Post:
  22. #157
    Kathu
    Thanked: 4323
    Pitty Johan Maree lost interest. Would have like to see the G-Wagon in action. One of the 4x4's with the best 4x4 systems.
    Also no Wrangler
  23. The Following User Says Thank You to grips For This Useful Post:
  24. #158
    St Albans
    Thanked: 1168
    Not surprising
  25. #159
    B-gowrie Randburg
    Thanked: 438
    ... A lack of comms between me and the First Wife ... '
    ... Maybe try VHF ?
    2002 Defender 130 DC HCPU. :
    Own the road... Any road ...
    ‘1981 R-Rvr Classic 2-Dr 3.5L V8 :
    The Greatest Rover.
    ‘1975 Series3 88 PUP :
    Simply ... Classic ...
    ‘2017 Metalian Mini ...
    A Home from Home
  26. #160
    Nov 2012
    Thanked: 1684
    1. Forum name - Coenoes
    2. Real name - Johan
    3. Vehicle manufacturer - Toyota
    4. Vehicle model - Hilux
    5. Drive - 2x4 4x4H 4x4L
    6. Low range - Y
    7. Traction control - Y
    8. Rear locker - Y
    9. Front locker - N
    10. Centre locker - Y
    11. Tyre brand -Yokohama Geolandar
    12 Tyre size - 265 65 R17
    13. Tyre type - All terrain
    Choose life
