Results 1 to 7 of 7
    Feb 2021
    Default Land Cruiser V8 Diesel: Single turbo Specs
    I need the specifications of the OEM turbo charger of the 76/70 Landcruiser V8 diesel
    Is it a Garrett, and if so which one ?
    What will also be of help will be the dimensions of the compressor wheel, if that is the only information available.
    Of course the dimensions of the turbine wheel also be a bonus.
    I am in the process of characterization of the induction system of the engine.
    I have so far created a design procedure for the intercoolers, by which the the efficiencies of the intercooler under varying load condition can be predicted.
    Furthermore, I would like to know the dimensions and/or characteristics of the largest hybrid compressor wheel that can be fitted to the machined out OEM housing.
    To characterize the turbo, I need to now the dimensions of the wheels and the scroll. ‚€‹
    Mokopane/Potch
    Thanked: 80
    Default Re: Land Cruiser V8 Diesel: Single turbo Specs
    Give Stallion Turbos a call, they will be able to give you all of the specs.
    VW Touran 2.0tdi - For the wife.
    80 Series cruiser - To use the fuel I save on the other two.
    Hilux - Work mobile
    Heimrich Swart
    Brilliant products are ruined by incompetent suppliers.
    Sep 2012
    Switzerland
    Thanked: 80
    A real Landcruiser comes with Biturbo
    ___________________________________________
    Transafrica with a well equipped Land Cruiser 200
    http://transafrica2012.blogspot.com
    Feb 2021
    "A real Landcruiser comes with Biturbo :-)"
    Not with 260 kW on the dyno !! Maybe 175 kW
    Wartburg.
    Thanked: 707
    Quote Originally Posted by Axis MC View Post
    To characterize the turbo, I need to now the dimensions of the wheels and the scroll. ‚Äč
    This sounds very interesting, please keep us posted!!
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
    ZS5CL
    Kathu
    Thanked: 3933
    Stock Turbo Garrett - GTA2359V
    Garrett Part no -842127-5001S
    Toyota Part no 17201-51011
    17201-51010
    Feb 2021
    Smile Re: Land Cruiser V8 Diesel: Single turbo Specs
    Thank you Grips !
