Results 1 to 16 of 16
    Feb 2007
    Tulbagh
    Thanked: 7
    Default Tdi Defender diy clutch fix.
    Last week my clutch peddle started squeaking and yesterday suddenly there was nothing, peddle stayed on the floor. Currently the peddle goes halfway to the floor, not further, and the spring will return it.
    I have to fix this myself, 1) I don't have the finances to have it done. 2) I have time. 3) I will learn a lot about my car.
    When asking around about where to start (I'm leaning to removing the peddle box first), somebody mentioned the thrust bearing fork which is prone to failing in Defenders. Is there a surefire way to figure out what's wrong before starting repairs? Any advice and suggestions will be appreciated, thanks!
    Land Rover Defender 90 Tdi
    Thanked: 658
    Default Re: Tdi Defender diy clutch fix.
    This is what we do to make sure it can not break again.
    I have a spare one, nothing wrong.
    If you open your box and see its the fork let me know i will post my spare one to you, no charge.
    Defender Kalahari
    Series 3 SWB
    Series 1 De Luxe Cab Pickup
    Series 1 Station Wagon 88''
  3. The Following 3 Users Say Thank You to imgreg For This Useful Post:
    Thanked: 186
    that doesn't sound like a hole in the clutch fork
    the halfway down description is the confusing bit
    there is a rod linkage about 3/4 way up the brake pedal that conects to the clutch master cylinder - which itself is bolted to the firewall
    so you won't see the rod operating
    i would loosen those two bolts and see if pedal depth follows it
    Feb 2007
    Tulbagh
    Thanked: 7
    Quote Originally Posted by imgreg View Post
    Thanks for the offer!will definately take you up when the time comes. When I eliminated any other possibilities, I will carefully follow the instructions as layed out here: https://forums.lr4x4.com/topic/5009-...r-clutch-fork/
    Feb 2007
    Tulbagh
    Thanked: 7
    Thanks for the reply. The first time it went, the peddle did go to the floor board, I then pulled it up by hand. When I tried to push it down again it would only go halfway.
    I'm not clear on which two bolts. The clutch peddle bits and the master cylinder is housed in a "peddle box", this box is bolted onto the firewall from the inside with six bolts, are you refering to two of those bolts?
    Thanked: 186
    i have a disco 1 so didn't think it would be that different
    the web pics i see looks like it's on the firewall inside the engine bay ?
    apologies
    Mar 2015
    New Germany
    Thanked: 838
    When you pressed the clutch was there there the normal resistance and then poof no resistance and straight to the floor,
    if so probably push rod has pushed through the clutch peddle, before you remove anything on brake peddle area I would unbolt slave and see in there
    2005 Defender TD5
  9. The Following User Says Thank You to clivemd For This Useful Post:
    Feb 2007
    Tulbagh
    Thanked: 7
    apologies
    I got these pics from Google. The first pic shows the 6 bolts where they're removed from the inside of the fire wall. The second one shows the complete peddle box assembly with the master cylinder, and the third image shows where the plunger goes into the master cylinder, accesable when you remove a little plate...this is from inside the engine bay.
ID:	604081   Click image for larger version.
ID:	604082   Click image for larger version.
    Feb 2007
    Tulbagh
    Thanked: 7
    I have difficulty to decide if I should go for the clutch fork or for the master cylinder. Looking at the master cylinder, there's no hydraulic fluid to be seen leaking anywhere down to the slave, also the plunger on the master looks like it's doing it's full stroke...I know I said earlier that the peddle only goes halfway, but it's further than that, it's difficult to judge because there's so little pressure on the peddle...which will make sense if there's a hole in the clutch fork.
    Right now I'm more inclined to think that the problem is with the clutch fork.
    Mar 2015
    New Germany
    Thanked: 838
    Happened to my 300TDi driving in town on way home clutch fine, next robot clutch in and poof straight to floor, clutch for gone, drove home crash changing,
    2005 Defender TD5
  13. #11
    Thanked: 186
    clive's suggestions makes sense
    needs 2 people though
    as top person presses clutch undo bleed nipple on slave
    should squirt out
    keep clutch pedal down and tighten bleed screw otherwise you drawing air in
  14. #12
    Mar 2014
    Brakpan
    Thanked: 294
    If i am alone i gravity feed it. Then i close up and pump it. 80 persent of the time it works
    Four wheels move the body,
    Landys move the soul.
    0735236742
    Current: Discovery 2 td5.
  15. #13
    Thanked: 505
    Where are you based
  16. #14
    Feb 2007
    Tulbagh
    Thanked: 7
    Where are you based
    I'm in Tulbagh, W-Cape.
  17. #15
    Feb 2007
    Tulbagh
    Thanked: 7
    Thanks, I'll do that. Hopefully I get some time tomorrow.
  18. #16
    Thanked: 505
    Quote Originally Posted by LuigiV View Post
    Sorry.... too far for me
  19. The Following User Says Thank You to GaryFrank For This Useful Post:
