Amarok v6 coolant leak
Results 1 to 7 of 7
    Jul 2017
    Paulshof
    Thanked: 329
    Default Amarok v6 coolant leak
    Appears I am leaking coolant.
    Friend phoned after my car was parked at his place for the day and said there is a patch of what looks like coolant on his paving. My check engine coolant light has come on aswell. Bakkie is going in tomorrow. Engine temps were normal on the short trip home.
    Anyone else experienced this? The driveway a fairly steep but this shouldn't matter, car is close to 60000kms now.
    2018 VW Amarok V6 Auto 4Motion
    2011 VW Golf GTI DSG
    2007 VW Golf GTI
    2003 VW Citi Life
    Jun 2012
    Thanked: 2251
    Default Re: Amarok v6 coolant leak
    in the V of the engine there is a plastic T piece thats prone to cracking, Id start there.
    Anton Muller
    2012 Q7 4.2 TDI
    Birkin SR20VET race car
  3. The Following User Says Thank You to mullerza For This Useful Post:
    Jul 2017
    Paulshof
    Thanked: 329
    Turns out it's a turbo seal.
    2007 VW Golf GTI
    2003 VW Citi Life
    Oct 2012
    otjiwarongo
    Thanked: 194
    Quote Originally Posted by Ooba View Post
    ok
    can u give us more info? can it be repaired or do they replace the whole turbo? did the bakkie show any change in temp? was it just the water on floor symptoms? power was still the same?
    2017 VW Amarok 3.0 TDi V6 4Motion D/Cab
    2020 VW T Cross Highline R Line
    2019 Bushlapa Miskruier 1616
    Jul 2017
    Paulshof
    Thanked: 329
    Quote Originally Posted by hein100 View Post
    ok
    Have a full maintenance plan so they are changing the pipe that comes with a new seal and clamp.
    Absolutely no changes in temp or power or sound or anything.
    Was just a bit of water with a reddish tint on the paving. This morning there was nothing under the vehicle, coolant warning light also did not come on this morning so decided to drive to the VW (3,5kms from home) very slowly. The check coolant light came on about 500m from VW, the car was not even up to temp yet.
    I can fetch the car later this afternoon.
    Good service from Pierre at Hatfield Rivonia I must add.
    2007 VW Golf GTI
    2003 VW Citi Life
  7. The Following 3 Users Say Thank You to Ooba For This Useful Post:
    STANDERTON
    Had the same problem with my V6, replaced coolant seal at turbo under warranty (+/-57000km)
    Jul 2017
    Paulshof
    Thanked: 329
    Quote Originally Posted by JACO PRINSLOO View Post
    Thanks Jaco. I am on 56000kms, strange
    2007 VW Golf GTI
    2003 VW Citi Life
