Results 1 to 8 of 8
Thread: Citroen C5
    Mar 2009
    Florida
    Thanked: 753
    Default Citroen C5
    Can anyone recommend a Indy that can do a check and repair to a Citroen C5 engine. It seems as if engine exhaust gasses are being discharged into the coolant. Engine still runs well but this could develop into a major failure if not tended to. Citroen dealers are ridiculous with their quote.
    I doubt if there is any damage to the head and think it is only the gasket that has gone. Citroen state that they won’t just replace the gasket.
    This is my run around vehicle.
    Jul 2016
    Thanked: 592
    Default Re: Citroen C5
    Which engine have you got? 3.0 v6 ?
    Mar 2009
    Florida
    Thanked: 753
    Yip, 2011 model.
    Jul 2016
    Thanked: 592
    The 3rd gen diesel one?
    Mar 2009
    Florida
    Thanked: 753
    Yes, lots of power and very good fuel consumption. A great ride.
    Thanked: 2263
    are you losing any coolant? Could be a failed egr cooler, might be worthwhile checking it out before doing a head gasket replacement.
    Anton Muller
    2012 Q7 4.2 TDI
    Birkin SR20VET race car
  7. The Following User Says Thank You to mullerza For This Useful Post:
    Thanked: 548
    Get somebody to pressure test the radiator. Last year I had similar symptoms, thought a head gasket popped. Turned out to be a leak between two sections of the radiator which was picked up by doing a radiator pressure test (Radiator was repaired for around R3k). Hope for the best!
    Dec 2007
    Thanked: 111
    This is the FORD / PSA 3.0 TDV6 as found in Discovery 4 and Jaguar's
    https://en.wikipedia.org/wiki/Ford_AJD-V6/PSA_DT17
    MikeBob should be able to sort you .... or another LR indie
    We had a Jaguar with the 2.7 V6 diesel as from D3 - yip in plat car that thing was great .. used 2 turbo's though and travelled.
    Nico
    Nico van Diemen
    '91 BYB - Big Yellow Bus - Ex-CT Tdi Disco
    '05 BOV - Big Orange Van - TDV6 D3 G4 It met a COW and is Gone, gone , gone ... replaced
    '11 - D4 V8 - BLACK (for now )
    '10 JK Sahara 2 Door - Open top for me and my boys - 3.8 V6 lifted muds bumpers sorted - Yip also orange
    '16 KIA SEDONA - 11 SEATS
    SWAMBO: Black RCZ
