Which engine have you got? 3.0 v6 ?
Can anyone recommend a Indy that can do a check and repair to a Citroen C5 engine. It seems as if engine exhaust gasses are being discharged into the coolant. Engine still runs well but this could develop into a major failure if not tended to. Citroen dealers are ridiculous with their quote.
I doubt if there is any damage to the head and think it is only the gasket that has gone. Citroen state that they won’t just replace the gasket.
This is my run around vehicle.
Yip, 2011 model.
Yes, lots of power and very good fuel consumption. A great ride.
Get somebody to pressure test the radiator. Last year I had similar symptoms, thought a head gasket popped. Turned out to be a leak between two sections of the radiator which was picked up by doing a radiator pressure test (Radiator was repaired for around R3k). Hope for the best!
This is the FORD / PSA 3.0 TDV6 as found in Discovery 4 and Jaguar's
https://en.wikipedia.org/wiki/Ford_AJD-V6/PSA_DT17
MikeBob should be able to sort you .... or another LR indie
We had a Jaguar with the 2.7 V6 diesel as from D3 - yip in plat car that thing was great .. used 2 turbo's though and travelled.
Nico
Nico van Diemen
'91 BYB - Big Yellow Bus - Ex-CT Tdi Disco
'05 BOV - Big Orange Van - TDV6 D3 G4It met a COW and is Gone, gone , gone ... replaced
'11 - D4 V8 - BLACK (for now)
'10 JK Sahara 2 Door - Open top for me and my boys - 3.8 V6 lifted muds bumpers sorted - Yip also orange
'16 KIA SEDONA - 11 SEATS
SWAMBO: Black RCZ
