Page 5 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 81 to 100 of 147
  1. #81
    Langs die rivier, op n berg
    Thanked: 3869
    Default Re: 4.2 tdi Patrol DC conversion
    Ja, propshaft word 2 piece met centre bearing
  2. #82
    Nov 2008
    Ellisras
    Thanked: 1071
    Klein verandering.
    Het aanvanklik beplan vir n 140 wheelbase. Dit gaan nie gebeur.
    Wil kajuit so h dat die agter seats hul vol beweging kan behou. En n 1900-2000mm loadbox.
    So dit werk nou uit op 150 wheelbase.
    Dit kan dalk help vir uit die oog pakplek agter die sitplekke op die vloer - geweerkluis?
    Dont blame yourself over past mistakes. Its like driving down the N1 while looking in the rear view mirror only.
    2000 Patrol GU 4.2D(onkey) "old-timer" and wise at 857 000 km
    2014 Patrol GU 3.0CRD "teenager" in puberty at 123 000 km
    2007 Echo3 Trailer "the nest" Braked Axle fitted at +60 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" at 125 000 km
  3. #83
    Nov 2008
    Ellisras
    Thanked: 1071
    Quote Originally Posted by Mike N View Post
    Met daai wheel base gaan jy definitief 2 piece propshaft nodig he, en 2 rugbyvelde om om te draai
    Patrols se knuckles draai verbasend skerp, beide my patrols se draaisirkels is effe beter as my NP300 DC
  4. #84
    Thanked: 3869
  5. The Following 2 Users Say Thank You to Reenen For This Useful Post:
  6. #85
    Thanked: 3555
    Hier kom 'n ding!!!
    Ettienne de Kock
    1998 Disco Tdi
    1959 SII 88"
    197? RRC
  7. #86
    Thanked: 9
    Question Re: 4.2 tdi Patrol DC conversion
    Enige nuwe verwikkeling?
  8. #87
    Thanked: 3869
    Yip. Hy vorder
  9. The Following 2 Users Say Thank You to Reenen For This Useful Post:
  10. #88
    May 2010
    HONEYDEW
    Thanked: 2609
    Yip. Hy vorder
    Nee man Reenen wys bietjie man!
    Zerubbabel 2 the 2008 4.8 turbo Patrol with some kit
    Nothing, not even a mighty mountain, will stand in Zerubbabels way! (Zech 4:7)
  11. #89
    Thanked: 3869
    Binnekort
  12. The Following User Says Thank You to Reenen For This Useful Post:
  13. #90
    Thanked: 3869
    Bak is verkort van 2.24 na 2.00. Not bad vir n dc.
    Onderstel is verleng met 750mm.
    Dit dwing my vir n lift kit en 35 tyres.
  14. #91
    Thanked: 45
    Ek hou van die woord keuse... "Dit swing my..."
    Enige sneak peak fotos al beskikbaar?
    Nato
    '13 Nissan Navara 2.5TDCI DC 4X4
    Ex '08 Nissan Hardbody 3.0 TD 4x4
  15. #92
    Thanked: 3869
    Dummy bak is op. Maar ek gaan n splinter nuwe fabrieks bak sny en gebruik. Het bsluit teen die 2dehandse een
  16. #93
    Thanked: 3869
    Al wat ek kan s: hy is nou klaar hoer as enige standaard bakkie. En hy lyk soos n plat worshond. Sy 32 bandjies lyk soos 195/14.
    6 lift, en 35 bande wag klaar reg vir hom
  17. The Following User Says Thank You to Reenen For This Useful Post:
  18. #94
    Thanked: 3869
    Bande is sorted
  19. The Following User Says Thank You to Reenen For This Useful Post:
  20. #95
    Thanked: 5222
    Bande is sorted
    Watse tyres is daardie Reenen?
    Gert Grobler
    VW Touareg V6 Tdi Escape; Land Cruiser 105
    Bush Lapa Boskriek 816
  21. #96
    Friemersheim, Southern Cape
    Thanked: 4639
    Quote Originally Posted by Nys View Post
    Moer grotes?
  22. The Following User Says Thank You to Prof For This Useful Post:
  23. #97
    Thanked: 663
    Unimog smaak dit my.
  24. #98
    Thanked: 3869
    Darem nie unimog nie.
    Net gewone muds.
  25. The Following User Says Thank You to Reenen For This Useful Post:
  26. #99
    Thanked: 4639
    Moer grotes?
    Net gewone muds.
    37' is moer groot
  27. #100
    Thanked: 3869
    Sal seker nou die 4.1 diffs moet regear na 4.7.
    Ek wil nie die 4.2 donkie ooreis nie
