Page 8 of 8 FirstFirst 1 2 3 4 5 6 7 8
Results 141 to 154 of 154
  1. #141
    Thanked: 598
    Default Re: White metal casting for restoration
    Quote Originally Posted by ghouwens View Post
    You need to look at your phone!
    Your casings are ready. I need to go through to Walmer in a little while so can drop them off if you want.
    Thanks so much Guy! Will look at my phone
  2. #142
    Thanked: 598
    A bit of an update ...
    Yesterday I made some time to tin the two casings @ghouwens so kindly made for me. I must say it has become a lot easier getting a good tin coverage although it still is a task and a half ... Name:  rolleye0014.gif
    This morning I made a few changes to the jig and installed the first casing to be cast full of white hot white metal...
    Tomorrow when I am feeling nice and fresh I will do my level best to cast a good new casting! Hold thumbs!
  3. The Following 3 Users Say Thank You to mygoggie For This Useful Post:
  4. #143
    Jul 2009
    Thanked: 351
    GOOD LUCK with the casting today !!!!!!
    Lynx Bashplate
    DIY Drawer system
    DIY Drop Fridge Slide
    My ULTIMATE dual battery box
  5. The Following 2 Users Say Thank You to SinWolf For This Useful Post:
  6. #144
    Thanked: 598
    And the effort was in vain ... we have a leaking vessel!
    Onto stripping and beyond ....
  7. #145
    Thanked: 1193
    Ai. Sometimes it pours. Good luck. Aanhouer wen. Ons staan almal agter jou en moedig jou aan.
  8. The Following User Says Thank You to Spiceman For This Useful Post:
  9. #146
    Thanked: 598
    I cleaned everything and made some refinements to the clamping plate to accommodate the smaller diameter casing. Taking my time to seal everything well, resulted in this ...
    A very neat looking casting!
    A bit of filing to remove the excess white metal and we have a very good casting!
    Onto making the second casting. First step is to get all parts to temperature. This takes quite a while and some patience is a virtue here ..
    I had to get the Boss to come and help as the final casting steps cannot be done by only one person. At least she is still smiling!
    That looks purty good!
    A bit of wire brushing to remove all the exhaust sealer and ...
    And another very good casting!
    Ringing of a white metal casting is a test to show that no cracks exists in the casting. A dull thud is the sound you do not want to here, so this casting is all good!
    Click the image to listen!
    Brain is still working on the lathe's wiring design and also the grooving of the bush ...
  10. The Following 3 Users Say Thank You to mygoggie For This Useful Post:
  11. #147
    Robertson/ Larissa, Greece
    Thanked: 4584
    Looks like you've done it before
  12. The Following User Says Thank You to Francois Theron For This Useful Post:
  13. #148
    Thanked: 598
    Too many times!
  14. The Following User Says Thank You to mygoggie For This Useful Post:
  15. #149
    Thanked: 1193
    Good work. Many years ago I had a Datsun P510 that needed a new extension housing bush. I should have known you then.
  16. The Following User Says Thank You to Spiceman For This Useful Post:
  17. #150
    Thanked: 598
    Uncle Brian helped me out again today by cutting the newly cast bushes to tad undersize and drill the hole.
    Looking good even if I say so myself!
    Yes Guy, I can also do the double casing shot!
    Tomorrow I will take the transfer case and the bush to Loftie to have installed and machined.
    Slowly getting there!
  18. The Following 5 Users Say Thank You to mygoggie For This Useful Post:
  19. #151
    Thanked: 3757
    Just make sure you have the white metal bearings cut to the correct clearance. It will be critical in a high speed application of prop shaft. White metal bearings can seize in seconds if not run at the correct clearances.
  20. The Following User Says Thank You to grips For This Useful Post:
  21. #152
    Thanked: 598
    We did investigate this and the correct clearance for oiled white metal is 0,05 mm (2/1000") on diameter. This was what was done then by Loftie and his crew.
    The sleeve is a nice and smooth sliding fit and rotates freely with no lateral play.
  22. The Following User Says Thank You to mygoggie For This Useful Post:
  23. #153
    Thanked: 2714
    And make sure your oil supply is unhindered and CLEAN.
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  24. #154
    Thanked: 598
    On this one I am a bit pedantic ... I change all the oils every 5000 km. Cheap maintenance!
    I am onto cutting the slots. I think I have come up with a way and solution. Test run over the weekend using some scrap uPVC piping of similar diameter.
  25. The Following User Says Thank You to mygoggie For This Useful Post:
