Page 5 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 81 to 100 of 154
  1. #81
    Thanked: 598
    Default Re: White metal casting for restoration
    Quote Originally Posted by EtienneB View Post
    in our consumption driven society it is all too easy to stop trying after the first stuff-up and maar go and buy the part. But you kept trying and now you have a successful product. Highly highly commendable Sir!
    Dankie @EtienneB
    Interesting bit of info is that Sweden has recently banned the throwing away of appliances and equipment. You must take it to a centre where old timers show the new generation how a screwdriver works and then the owner must repair the item. Only if the old timer certifies that the item is FUBAR may it be sent for recycling.
  2. The Following 3 Users Say Thank You to mygoggie For This Useful Post:
  3. #82
    durban
    Thanked: 1485
    Clamp it on a CNC table and cut the installed bush to size. That is the way we decided.
    Okay so its not going to be line bored.
    Many ways to do this .It could be clamped to a faceplate and bored or clamped to a milling machine table and bored .I would think if it were bored true in a four jaw and pressed in you couldnt be far off true.
    I dont have friends with cnc . . Will you take lots of pics.
    I just love how persistent you are . You don't give up hey.
    I could fill a garage up with incomplete projects .I have been curious to know how to do this white metal story because I have a lathe we are trying to repair where we have two bushes that could use this process.
  4. #83
    Thanked: 598
    You know where to send these two bushes now ...
  5. #84
    Kathu
    Thanked: 3754
    Nice thread. Nice learning curve in white metal casting. Hats off for your effort. Another solution will be to keep the OEM bush and crimp a sleeve onto the slip joint to match the OEM bush.
  6. #85
    Thanked: 598
    Thanks. A sleeve would not work as you have only about 2mm on diameter to work with in terms of white metal thickness.
  7. #86
    Thanked: 598
    Good news! I received the installed and precision machined bearing back today from the machine shop!
    The owner said that this is one of the best casted white metal bushes he has seen.
    Pressed into place and machined to 0,0025 mm clearance on diameter.
    I am just glad it came out so well and that it is perfect fit for the new splined sleeve!
    Now onto carving the oil grooves!
  8. The Following User Says Thank You to mygoggie For This Useful Post:
  9. #87
    May 2016
    Thanked: 3787
    Well done!!
    Even more respect!
    2006 VW Touareg V10 (Sold)
  10. #88
    Nov 2011
    Langebaanweg
    Thanked: 1668
    Personally I think the next stage is the scariest.
  11. #89
    Thanked: 598
    Well done!!
    Even more respect!
    Thanks @4eTouareg it means a lot coming from you!
    Yeah, I have given this a LOT of thought and I have practised a bit. It will have to be done by hand as a rotary bit simply gets blocked and you have little control.
    I will have to make some form of scraper and scrape the grooves out. Like we do in woodwork when you do an inlay.
  12. The Following 2 Users Say Thank You to mygoggie For This Useful Post:
  13. #90
    durban
    Thanked: 1485
    That looks really smart. Well done . Where do you get the white metals. I wonder if its the same stuff spoons are made of for fishing.?
  14. #91
    Thanked: 598
    No idea if the spoons are made from white metal. I doubt it as white metal contains lead.
    I got this batch from an engineering shop. The manufacturer is Fry. You can also visit engine rebuilders and ask for the old main and big end bearings and simply melt the white metal from the shell.
  15. #92
    Cape Town Southern Suburbs
    Thanked: 1463
    By spoon he's referring to the shiny fishing lures.
  16. #93
    Wilderness
    Thanked: 1428
    9
    Use a roundnose chisel and a hammer to cut oil galleries. Very much like engraving, but with bigger tools. Remember, bigger does not always mean better. As an appy, we spent hours, cutting keyways and oil galleries by hand. It is quite satisfying when finished.
    Pieter Kemp.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
  17. #94
    Thanked: 598
    Yep, I know it is the shiny lure and I have never seen polished lead remain bright and shiny. For that reason I said it contains lead ... However with @plunger you never know what he feeds fish with!
  18. #95
    Thanked: 598
    Dankie @Pieterk, probleem is die white metal is net sowat 1,5mm dik ... Daarom gaan ek moet skraap met diepte gids.
  19. #96
    Thanked: 1569
    Not an expert, but this is what I would use.
    https://images.app.goo.gl/y8mP4Lc23HgDXR1s6
  20. #97
    Thanked: 598
    Yep, that is what I had in mind and then the constant depth issue came to light. I will post a sketch of what Brain told me to do and which I am now building.
  21. #98
    Thanked: 1186
    I am so glad you got it right although I'm quite upset that tappitalk didn't tell me this thread is cooking. I was lucky to get the link again on the lathe thread.
  22. #99
    durban
    Thanked: 1485
    Theres nothing in my workshop that can measure to 0.0025mm..I wonder if this couldnt be done in a lathe using a very course thread.Or how is rifling done in a rifle barrel.?
  23. #100
    Thanked: 598
    The correct way is in a lathe with a thread cutting clutch mechanism. Uncle Brian tried to explain to me how it works, which is interesting. Alas I have never seen something like this so I can only imagine what it looks like!
