Just a tip on clearance. If you cannot get the jack under the lifting point, drive the deflated wheel onto the spare wheel first, this will create clearance.
Brandt Theunissen
2019 Mahindra S6 Pik Up S/C 4x4
2007 Mercedes Benz ML500 5.5
1968 VW Beetle 2276
This is good advice.
I do something very similar with a 10 ton bottle jack that I bought so far back that I don't even know anymore how much I paid for it, but would not have been over the top.
Most likely was from either Midas or Autozone.
I still use it, it has not failed in all those years and let me tell you that the old Suuz has been well overloaded and overlanded and even in overloaded state sometimes with the trailer still hitched as well, it has not failed to get it up
It is a very good idea to have a backstop in case it falls over though maybe due to the vehicle moving (soft sand or muddy conditions) or uneven terrain.
So find something to put under the raised vehicle near the jacking point.
Peter Hutchison
Platkar = Chevy Spark 1.2
Peter Hutchison
After many years I decided to dump the hydraulic bottle jack.
It topped over in the load bin, leaked oil and when trying to use it the thing failed - consider it being quite a decade or 2 old.
Moved to a mechanical bottle jack, so far no issue.
Should you get sand and dust in strip clean, grease and it works again.
As a sturdy base I modified the high lift jack plastic base and for the last 10 years had no issues yet.
Had to clean it once and greased just for fun after 8 or 9 years.
Buy one that has the height to fit underneath what ever you need to lift.
Mine is a 5 ton as it must fit under the vehicle, the 8 ton one was just to high with the base.
Midas use to sell them many years ago.
ZS5CMA
So a question on the hydraulic ones. How do you pack/store yours for travel, always find it a mission to pack it safely in the cabin somewhere. Such a heavy object and wants to be stored upright. It almost needs a dedicated strap-down place. That's my biggest irritation with them.
My reason for switching to the mechanical on. You can store it flat wrapped in a piece of cloth.
Takes some thinking to use it as you need to wind it instead of pump.
It never failed yet despite that once I used it, it sounded a bit grinding due to sand inside.
Striped and cleaned only a while later.
Midas Special, my 2.5 Ranger had similar jack painted black as standard.
Needed one for the off road trailer and found this at Midas.
It now stays in the 3.2 Ranger as it comes with a scissor jack and that piece of steel I don't trust.
Needed about 300 mm so the high lift plate worked perfect with a bit of mod.
