4x4 Trailer recovery in soft sand
Results 1 to 7 of 7
    May 2010
    Pretoria North
    Thanked: 22
    Default 4x4 Trailer recovery in soft sand
    Hi All,
    When towing a 4x4 trailer through very thick soft sand, it is normally the trailer that got stuck.
    After seriously got stuck in deep soft sand on the West Coast, I came up with the following solution to recover my 4x4 Trailer that worked for me.
    - To prevent the jockey wheel to sink into the sand when pulling it out of the sand, I place a piece of conveyor belt under the jockey wheel and undo from the vehicle.
    - To prevent the jockey wheel pulled off from the conveyor belt by the recovery vehicle, I secure the belt to the front of the trailer frame.
    (see photos attached)
    Let me know your views on this mod?
    Attached Files Attached Files
    I'm addicted...to CAMPING...!!!
    Cheers...my campsite is waiting...!!!
  2. The Following 9 Users Say Thank You to soekiets For This Useful Post:
  3. #2
    Thanked: 5782
    Default Re: 4x4 Trailer recovery in soft sand
    Quote Originally Posted by soekiets View Post
    Hi All,
    Very good plan that!
    Andrew van Staden
    Jun 2007
    Thanked: 31
    Great idea
    Current planet killers
    Disco 3 V8
    Colt Rodeo 2800
    Land Cruiser 79 V6
    Previous
    SIII Chevy 4.1 Straight 6
    Forward Control SII
    Rangie Classic 3.5 V8
    Rangie Classic Chevy 5.7 V8
    Defender 2.8 Straight 6
    Disco 1 3.5 V8
    Disco 3 TDV6
    Disco 3 V8
    Disco 1 V8
    Disco 2 TD5
    http://heine9999.wordpress.com/
    Thanked: 265
    Brilliant idea!
    It also uses the KISS concept (Keep it simple stupid).
    2018 Ranger DC 2.2 XLS Auto 4x4
    Bushtech Canopy and goodies
    Canon 5DMkIV with L-goodies.
    Thanked: 281
    Not sure if this was done, but many people forget to deflate the trailer tires as well when towing in soft sand.
    But it's a great idea if you want to winch your trailer out of the sand.
    2007 Nissan Pathfinder LE 2.5dCI 4x4
    2013 Nissan Xtrail 2.0dCi XE 2x4
  7. The Following 4 Users Say Thank You to IcePick88 For This Useful Post:
    Thanked: 1442
    Hi All,
    It very much depends on your circumstances. I had my boat on the beach in Sodwana and the sand was very soft. Drop your trailer pressures as much as makes sense to avoid it getting stuck in the first place.
    Have you got a compressor? I think this is pretty much essential as you may need your tyres up and down quite a lot depending on the what you are up to.
    I also ran into problems with my trailer jackey wheel sinking into the sand when I tried to move from the front tow hitch to the rear. I used a car mat but your conveyor idea is even better.
    Also works well for recovery so thanks for sharing your ideas.
    Gaborone
    Thanked: 1154
    Instead of the conveyor belt (which I don't have) I use my recovery spade, pull the winch cable through the handle grip and place the spade blade under the jockey wheel.
    The spade acts as a slide over the sand and even when changing direction, it follows the direction of the cable.
    No additional equipment needed
    Walter Rene Gygax
    Kalahari Safari
    ORRA Call:​ WB58 | ICASA ZRF430
    Nissan Patrol GU TB45
    E39 - 540i for the open roads
  10. The Following 6 Users Say Thank You to Kalahari Safari For This Useful Post:
