Results 1 to 3 of 3
Hybrid View
    Thanked: 1304
    Default Hyundai's Variable Valve Duration Tech Is a Genius Piece of Engineering
    "Hyundai recently introduced a new piece of engine tech into its lineup called Continuously Variable Valve Duration (CVVD). Similar to variable valve timing or variable valve lift, it physically alters the way the valves operate within the engine. But as Road & Track contributor Jason Fenske explains, Hyundai's solution is especially impressive.
    CVVD works exactly as it sounds. It's a system within the head that can alter how long valve stays open within the combustion cycle, allowing for more or less air to travel in and out of the cylinder, depending on the engine's rpm. It works using a specially designed camshaft that can alter the position of each cam lobe relative to its shaft using an actuator attached to the motor. It's some clever engineering that's best understood watching Fenske's models.
    The best part of this system is its flexibility. Because it's continuously variable, it can be optimized to work at every single part of the rpm range, rather than just two chosen points (which is how variable valve timing and variable valve lift work). Hyundai says the system allows for a five percent improvement in economy, a four-percent increase in performance, and a 12-percent decrease in emissions. ..."
    Thanked: 6785
    Default Re: Hyundai's Variable Valve Duration Tech Is a Genius Piece of Engineering
    BMW has the vanos and then the valvetronic system, since 2001.
    I think it is basically the same outcome..
    Each individual valve can be manipulated through the whole rev range.
    https://en.wikipedia.org/wiki/Valvet...0regular%20use.
    https://en.wikipedia.org/wiki/VANOS
    Andrew van Staden
    Thanked: 789
    Have a look at Fiat's Multiair system, it's brilliant.
  4. The Following User Says Thank You to faniedup For This Useful Post:
