Results 1 to 7 of 7
    Thanked: 479
    Default Garmin basecamp on Big Sur
    Absolutely no response, anybody else having the issue?
    www.lani4travel.com
    Louis Le Grange
    Thanked: 479
    Default Re: Garmin basecamp on Big Sur
    Hmmm seems like there is an update.
    Lets see.
    www.lani4travel.com
    Louis Le Grange
    Feb 2017
    Santa Cruz, CA
    Thanked: 273
    Update to Big Sur or update to Basecamp?
    I read somewhere else that if you go to the View menu and select "view 3D map only", even though a lot of maps are only 2D (T4A), that makes basecamp function okay on Big Sur.
    True? Let us know how it works out, I have been holding off upgrading because of this.
    Blog of our African travels: stuckinlowgear.com
    Thanked: 479
    Quote Originally Posted by CalDriver View Post
    Basecamp update. Yes only changing it to 3d makes it workable but still sluggish. Cheeses me off since Garmin new about this for quite some time. Apparently started in beta testing of Big Sur already and it is still not fixed.
    www.lani4travel.com
    Louis Le Grange
    Feb 2017
    Santa Cruz, CA
    Thanked: 273
    Well, Garmin is certainly not famous for quick software or good updates, but hopefully they'll get there soon.
  6. The Following User Says Thank You to CalDriver For This Useful Post:
    Thanked: 321
    Works for me.
    Dirk Meintjies
    Sometimes you find yourself in the middle of nowhere. And sometimes, in the middle of nowhere, you find yourself.
    Aug 2008
    Utrecht
    It almost froze completely with 2D view.
    3D View Only seems to be working fine (although graphics are a bit fuzzy).
  9. The Following User Says Thank You to mbremer For This Useful Post:
