Results 1 to 3 of 3
    Malmesbury
    Thanked: 169
    Default opel corsa bakkie heater control problem
    i have a opel corsa 1.7 tdi bakkie ,any owners who has one
    the problem with it that when switched on at the blower and you select it on cold it stays on heat , google only explains about the heater not working ,and i have to put the aircon on to cancel the heat out .
    alberto pereira
    Colt clubcab 2.8tdi 4x4 2005
    Ford Fiesta 1.4i (SWAMBO]
    opel corsa 1.7 dti 2006
    Jul 2013
    Thanked: 394
    Default Re: opel corsa bakkie heater control problem
    My son had a chevy 1.4 same problem , but the air vent control ie feet to face .
    The cable controling the setup unhooked. I rmoved the console and manually adjusted the vent to face side.
    Jy moet maar iemand met klein handjies vir jou help.
    Groetnis
    Coenie
  3. The Following User Says Thank You to janseekat For This Useful Post:
    Malmesbury
    Thanked: 169
    dit is wat ek vermoed het ,gaan die naweek strip. dankie
    alberto pereira
  5. The Following User Says Thank You to Alberto For This Useful Post:
