Series III Synchronize Twin SU Carbs on Series 3 R6
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 44
    Aug 2020
    Default Synchronize Twin SU Carbs on Series 3 R6
    Evening, I want to synchronize the air intake on my SU carbs, but needs a airflow meter also known as a Uni-Syn meter / gauge.
    Any one selling it or know where I can buy it?
    I am based in Pretoria.
    Ruimsig
    Thanked: 19413
    Default Re: Synchronize Twin SU Carbs on Series 3 R6
    Gunson make a carb balancer as well as the colour tune tool.
    They are represented in SA by Wingate Motors:
    https://www.wingate.web.za/gunson-workshop-tools/
    If you type gunson carb balancer into goggle you will get a number of alternatives such as bangood at R688.88
    Here is a quick video of the Gunson kit
    https://www.youtube.com/watch?v=LyUek-lAN5o
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
  3. The Following User Says Thank You to Estee For This Useful Post:
    Barberton
    Thanked: 1867
    $34.00 - that's ZAR500.00!
    Have you tried listening through a short piece of garden hose?
    The colour tune is a nice piece of kit and there isn't really a suitable and cheap MacGyver to substitute.
  5. The Following User Says Thank You to RoelfleRoux For This Useful Post:
    Mar 2007
    Thanked: 110
    Colour Tune is intended to set the air fuel mixture, not balance the carbs. I used the balancing kit on my then Datsun 1200 GX Coupe, it worked perfectly.
    Unfortunately I lost the float and reverted to a small pop rivet, I worked as you don't work with calibrated values, just reference points.
    2015 Pajero Sport 2,5 Di-D 4x4 5-spd Auto, STOFPAD eng & gbox plate, new engine courtesy Mitsubishi at 95k km.
  7. The Following 2 Users Say Thank You to Thys Willemse For This Useful Post:
  8. #5
    Wilderness
    Thanked: 1405
    Do yourself a favour and speak to your local spares shop. They may have a cheaper alternative. I have a cheap balancer, which I bought many moons ago, and it has been doing good service. It consists of an adjustable plug for the carb inlet with a pipe and a gauge with a little float indicating the vacuum drawn. Double carb vehicles are not common anymore and could well disappear altogether. It is not something which is used often. Once those carbs are adjusted correctly, what else would you use it for?
    Pieter Kemp.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
  9. The Following 2 Users Say Thank You to Pieterk For This Useful Post:
  10. #6
    Barberton
    Thanked: 1867
    Quote Originally Posted by Thys Willemse View Post
    Correct, but unless you do both balance and tune, the job is never done. I learnt on an Austin 1100 (with twin SUs) and later on a Datsun 1600 SSS.
  11. The Following User Says Thank You to RoelfleRoux For This Useful Post:
  12. #7
    Rangeview Krugersdorp
    Thanked: 1472
    We had a rough set of plastic tubing nailed to a plank on the garage wall. Middle loops filled with a very thin oil.
    My memory has gone but someone will know how to make it for 50 bucks?
    Ford Figo 2016
  13. The Following User Says Thank You to duncang For This Useful Post:
  14. #8
    Ruimsig
    Thanked: 19413
    Indeed, there are probably plans on YT. But the OP owns a Land Rover with SU carbs so I suspect he will get years of use from a commercial carb balancer and a compact one he can chuck into his jolly box which most LR owners have in the back, in case he needs it on his travels
    Hummer H3 V8
    W.A.P Objectivist
  15. The Following User Says Thank You to Estee For This Useful Post:
  16. #9
    Amanzimtoti
    Thanked: 200
    Believe it or not thatís the most accurate method ( even though the cheapest)
    Have a rig like that attached to my garage wall for the several BM ďBoxersĒ Iíve owned over the years.
    If you have a ďbleedĒ screw / plug on each inlet on the manifold this method works. Just make sure carbs are close to being in balance when you connect up tubes, else oil ( I use brake fluid ) gets sucked up by carb with highest vacuum.... no damage caused just plenty smoke from exhaust....soon clears
    I have a Gunson Carb Balancer kit as well but problem is Iím in Durbs and OP is in PTA.
    If you donít come right send me a pm and maybe we can make a plan to get it to you on loan ( as a rule I donít sell my tools no matter how seldom theyíre used )
    Take care and stay safe.
  17. The Following User Says Thank You to Andrepb For This Useful Post:
  18. #10
    Gqeberha
    Thanked: 4880
    Maybe speak to the older motorbike mechanics? My Goldwing needed that, and the mechanic had a 4 carb one available (but he works on older and carb bikes).
  19. The Following User Says Thank You to Dirk For This Useful Post:
  20. #11
    Thanked: 1472
    Think ours had cochineal for colouring ?
    Ford Figo 2016
  21. The Following User Says Thank You to duncang For This Useful Post:
  22. #12
    Thanked: 261
    I was looking at an old Rolls Royce today and spoke to the 30ish mechanic about balancing the carbs. He recons his father can/could do it almost to perfection with a screwdriver and a 10mm spanner.
    Si vis pacem, para bellum
  23. The Following User Says Thank You to thabogrobler For This Useful Post:
  24. #13
    Aug 2020
    Thank for all the feedback.
    I think I will not have a air flow meter on Saturday.
    Sometime back I read you can also do it using a plastic pipe.
    Anyone knows how it works or a link to an article explaining it perhaps?
  25. #14
    Nigel
    Thanked: 2459
    Easiest for me is to start with the basics.
    Make sure the needles are straight and not worn.
    Loosen the balance bar so you can adjust each individually.
    Adjust the mixture on both the same.
    Now start.
    Lift each plug lead and get them to affect the idling the same.
    Once you have each plug lead to affect the idling equally, you should have the cabs running the same.
    Now pick up the balance bar to actuate both carbs equally.
    PS. Make sure your plugs are good and the gaps are set equally.
    Uniglide
    +27 zero eight 2 four 95 9252
  26. #15
    Jan 2015
    Thanked: 451
    Guy B. Vergoes Houwens
    2014 LC76 4.5 V8
  27. #16
    Aug 2020
    Thanks for the explanation.
    Based on the videos I looked at, they adjust the air intake on idle speed before starting with the mixture.
    The rest sounds easy.
    And at the end, they adjust the idling speed and adjust air intake on +/-1600 revs.
    Now start.
    Now pick up the blance bar to actuate both carbs equaly.
  28. #17
    Aug 2020
    Quote Originally Posted by ghouwens View Post
  29. #18
    Thanked: 1434
    I had an R6 and I did have access to a carb balancer at the time, but a straw or pipe put into the throat of the carb will give you pretty good results. You just listen for both carbs making the same slurping noise.
    I eventually chucked the R6 motor and put a Nissan LD28 in there and it was running great guns when I sold it.
  30. #19
    Thanked: 498
    Get a decent vacuum gauge and you can set your timing with it as well......old school mechanics donít use timing lights.
  31. #20
    Barberton
    Thanked: 1867
    Please explain... honest question.
