Results 1 to 20 of 31
    Jul 2015
    Gordons Bay,Helderberg
    Default 2011 Hilux broken strut mount.
    Hi guys so Ive had my bakkie for about 2 years now, today after some off-road I see the following crack on top of the strut, it looks like it's both sides equally. This vehicle has a 2 inch lift kit with a small spacer. The rollbar was not moved after the suspension raise(I bought the vehicle like this) I think perhaps the rollbar caused this by rubbing up against the spring as in the pic. So my question to you would be could I get this welded up? I have a few friends with Excellent welding skills. Have you seen anything like this before? Any help would be appreciated.
ID:	600523Click image for larger version.
ID:	600524Click image for larger version.
ID:	600525Click image for larger version.
    Thanked: 17104
    Default Re: 2011 Hilux broken strut mount.
    Shock too short for the lift.
    Jul 2015
    Its been running for more then 2 years like this. Offroading almost every weekend lots of wheel lifting, only now this crack happens. My purpose for posting this is to find out if any other Hilux okes have had this problem. Also this could serve as a warning to those who run a lift and have not adjusted the sway bars accordingly.
    Thanked: 17104
    Metal stress is cumulative. The fracture takes time as the stress builds and the metal work hardens.
    Wartburg.
    Thanked: 707
    I have had it on my D4D, standard suspension, but hard working farm van.
    The van was due for a service anyway and I just asked Toyota to sort it out, the part is available from Toyota and the panel beater cut the old one out and welded in the new part, no big dramas. Our local Toyota has a panel shop as well.
    On one of our other vehicles , D4D, I have welded that up myself, and it worked well, just bevel it out a bit first.
    This is most probably not recommended, but worked just fine, still running like that.
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
    ZS5CL
  6. The Following User Says Thank You to Chris8d For This Useful Post:
    Jul 2015
    Quote Originally Posted by Chris8d View Post
    Did you reinforce the mount at all or just weld the cracks closed?
    Wartburg.
    Thanked: 707
    Just welded the cracks.
    ZS5CL
  9. The Following User Says Thank You to Chris8d For This Useful Post:
    Jul 2015
    I find it quite interesting that this obviously is a problem with these bakkies. Here we have 3 separate vehicles with this issue. I wonder if this is a common thing and people are just keeping it on the lowdown. I'm part of a lot of Aussie forums where guys are running fully kitted rigs with 33 inch tires and overlanding with some serious weight and I hear of struts breaking, maybe the odd strut bottom as well but never the strut mount in the way that it has on my vehicle. Something to think about.
    Mar 2012
    Thanked: 120
    Weld her up. Not uncommon on vehicles with uprated springs. You can always reinforce it with gussets etc to strengthen it in future.
    Do you have heavier duty springs? Any accessories fitted to the front of the vehicle?
    Rowan Alexander
    http://www.fridayavieclub.co.za
    Mar 2012
    Thanked: 120
    Check for coil bind before the bump stop is being reached. And remember to account for bumpstop compression as they are rubber.
    Easiest way to do this is to physically measure the gaps between the coils of the spring.
    Rowan Alexander
  13. #11
    Jul 2015
    Quote Originally Posted by Alxrow001 View Post
    Hi there, yes I have a TJM bullbar and winch upfront. The vehicle currently runs OME springs and shocks upfront.
  14. #12
    Mar 2012
    Thanked: 120
    Reading your original post again I see that it has OME 2" + small spacer.
    I'll put money on it that the strut is being fully compressed before the bumpstop is being reached. This will transfer all the stress into the shock mount and result in fatigue.
    Rowan Alexander
  15. The Following User Says Thank You to Alxrow001 For This Useful Post:
  16. #13
    Mar 2012
    Thanked: 120
    Quote Originally Posted by pampoenluke View Post
    Add that weight to the previous post and see how the problem compounds
    Rowan Alexander
  17. #14
    Mar 2012
    Thanked: 120
    Winch running steel wire or synthetic rope?
    How about these, are they also fitted?
    Spotlights?
    Bashplate?
    Dual battery under the bonnet?
    Rocksliders?
    Rowan Alexander
  18. #15
    Aug 2019
    Thanked: 327
    I have plenty of mates who used to own Vigo's. Most had the spacers fitted to the front after installing steel bumpers and winches.
    Never seen any cracks. But we are more for the show than hard core 4x4 guys
  19. #16
    Aug 2019
    Thanked: 327
    I recon a good weld with sort that out in no time
  20. #17
    Thanked: 1324
    Before you weld the crack, drill a hole at the end of it. This "stop-drill" will help prevent the crack progression in the future.
    2004 Disco 2 Td5
    Suzuki SJ410 (being rebuild)
    VW Touran 2.0Tdi
    Lotus 7 (replica - not a kit)
  21. The Following 4 Users Say Thank You to Paul#25 For This Useful Post:
  22. #18
    Cape Town Southern Suburbs
    Thanked: 1509
    Maybe also use extra thick fender washers under those 2 nuts on either side of the center strut bolt. The crack developed just off from the one nut, fender washers will help spread the load, you could even weld them on when repairing the crack.
  23. The Following User Says Thank You to Skylark For This Useful Post:
  24. #19
    Jan 2020
    Thanked: 122
    Welding it will fix it - but it will reoccur down the line. Even the best welds can have weak points - I would hate to have this whole thing crack in half on a gravel road at higher speeds. There must be better aftermarket solutions for lifting a D4D. I suggest you weld it for now and spend some cash on a safer lift-kit
  25. #20
    May 2016
    Thanked: 4025
    The impact on the strut mount should be "damped".
    This is achieved by means of
    • Mounting rubbers
    • The shock never reaching full extension (and becoming solid)
    Maybe one of the above has been compromised.
    2006 VW Touareg V10 (Sold)
  26. The Following User Says Thank You to 4ePajero For This Useful Post:
