Results 1 to 13 of 13
    Nov 2019
    Question ZD30 Rough Idle After Fuel Filter Replacement
    Good day guys. I recently serviced my 2004 Nissan Hardbody 3.0 16V Td and replaced the fuel filter + sedimentor. I also replaced all fuel hoses and clamps with new ones as they were looking tired and somewhat perished.
    I've done this many times in the past and its never given me issues. I primed the filter as usual. I noticed it wasn't getting harder and the bakkie didn't want to start. So I disconnected the hose that sits between the filter and injector pump, primed it and saw that diesel was indeed coming out. I then reconnected the hose and then primed it. It hardened and all was well. I then started her up and now its got such a rough idle. I let it idle for a long time... even up to operating temperature and it hasn't changed at all. I took it for a drive in hopes that any air bubbles would just pass through. No difference.
    I disconnected the hose from the fuel filter and the sedimentor. Primed a little more. Reconnected the hoses. Primed it again and it stiffened up once again. I started the bakkie no problem. The idle is still rough and constantly feels like its going to stall.
    I then read somewhere that you should disconnect the battery and have the ECU reset itself. I thought it was worth a try. Didn't help at all.
    This is 2 days in the making and I've got no idea what to do. I don't want to drive the thing because I'm worried it leaves me on the side of the road. Like I said, I've done this many times and I've never had issues...
    Any theories, suggestions, help would be much appreciated!
    2001 Land Rover Discovery 2 Td5 +/- 270 000km
    2004 Nissan Hardbody 3.0 16V Td +/- 278 000km
    Thanked: 20097
    Default Re: ZD30 Rough Idle After Fuel Filter Replacement
    Sounds like some sediment went down the pipe to one of the injectors.
    Thanked: 1694
    Is there a chance that the hoses/clamps are not sealing properly or maybe you got the fuel/feed/return lines the wrong way around (not sure if this is relevant here)?
    Padraic Berry
    Nov 2019
    I thought so too. I checked everywhere multiple times and everything looks perfect. I went over everything with a fine tooth comb, and its exactly the way it should be. All clamps are tightened, filters are tight but not overtightened, no lines mixed. Its exactly as it should be.
    Nov 2019
    How do you check for that or what should I do to sort that out?
    Thanked: 20097
    Quote Originally Posted by LR Disco 2 View Post
    I wouldn't even try to sort that out in a home workshop.
    You're a little screwed until the workshops open in the new year.
    The only option is to try add some injection system cleaner to the fuel tank and take it for a drive.
    Nov 2019
    Right, I'll give that a shot after Christmas and let you know how it goes. For the meantime, I won't be moving that bakkie anywhere.
    Thanked: 20097
    And now you do understand why Murphy waits for precisely this time of the year to do his best work.
    Nov 2019
    Well said!
    Nov 2019
    Gents, it was just air in the fuel system. Specifically trapped air by the fuel pipes going into the injectors. It's never happened to me before, thus being so confused as to what was wrong. I ended up loosening the size 17 nut by the injectors a little. Had the air leave the system, fastened the nut again, and it already improved drastically. I then let it idle a bit and took it for a 20km drive; slow, normal and fast driving and now its perfect.
    I'm glad I've learnt something new... I do however feel very stupid for not using my common sense. Maar, so leer ons...
  11. The Following 2 Users Say Thank You to LR Disco 2 For This Useful Post:
    May 2016
    Thanked: 9896
    Murphy was an optimist - things get much worse than he ever imagined.
    2003 Mitsubishi Pajero 3.2 Di-d LWB
    May 2016
    Thanked: 9896
    Glad you got it sorted - I was starting to fear a damaged injector (air can do that).
  14. The Following User Says Thank You to 4ePajero For This Useful Post:
  15. #13
    Thanked: 20097
    I think a Christmas Elf helped LR Disco 2 this time round.
