I was heading up to Sodwana today and there were multiple roadblocks. I had my trailer "delicensed" as my trailer GVM was over my tare mass. There was no interest in the actual trailer mass, just the GVM on the license disc, so this could mess up a few peoples holiday.
I kind of expected this in Cape Town, however I did not think the guys in KZN were that boned up on the trailer laws but there were totally up to speed.
Beware as soon as you head north of Ballitto.
Stephen
Which areas along the N2?
We are heading from Secunda, Ermelo via Piet Retief and Pongola to Hluhluwe
2013 Toyota Hilux 3.0D4-D 4x4
Bush Lapa 810 Miskruier
I do not understand, GVM will always be greater than Tare.
GVM is the total mass that includes the empty trailer weight and the load.
Tare is the weight of an empty or unloaded trailer.
Did they weigh the trailer on a weighbridge?
2009 Toyota Hilux 4.0 V6 Raider D/C AT
I believe he means his trailer GVM was higher than the tow vehicle tare.
True.
That is illegal and rightly so.
Johan Maree
Isuzu 300 d-tec
MB Gwagen G350 Bluetec
Nissan NP300 2.4 4x4
Conqueror UEV-25
You must have towed a very heavy trailer. Amarok tare 1848 kg.
Xplorer Gvm 1650 kg. As a reference.
Rob Kirk
Amarok V6.
Sym 200 scooter 2 x 1, CVT transmission, 4V OHC, 11.4 kW, 15NM
0-60km/h in about 10s (downhill), Top speed - 100km/h (on a steeper downhill)
Ground clearance : 125mm on 16-inch rims
Tare : 134kg, GVM : 250kg (approx), GCM : 250kg (approx), Towing capacity : 0kg
Best of all : 4L/100km, town driving and pinning it...
What is rated by the manufacturer (what you mention) and what the law specify is two different stories.
You can accept that on the farm you can safely tow that weight but not allowed on a public road.
Same with trucks. Tow allowance is not only determined by number of axles. Here you may have enough axles but the hp and brakes may not be enough.
Johan Maree
Isuzu 300 d-tec
Conqueror UEV-25
Rob Kirk
Amarok V6.
John 2014 Toyota Hilux 4x4 3.0 D4D
Baobab BL1715 "Kamba"
"I never knew of a morning in Africa when I woke up and was not happy" - Ernest Hemingway
Kgalagadi 2019 Namibia 2019 Gonarezhou 2019 Mana/Tafika 2018 Kgalagadi 2017 Lion, Hippo, Eland Leguaan, Python
What the official checks are the discs and do they correspond. Whether the trailer is loaded up to gvm is not regarded.
Similar to spotties on the roof or light bars. Whether they are connected or switched off is irrelevant. Fitted on a road vehicle is illegal finish and klaar.
Johan Maree
Isuzu 300 d-tec
Conqueror UEV-25
But how can they deem the trailer unroadworthy? Surely the problem is the combination i.e. if he were towing it with a Ford F350(Just an example) then it would have been a legal combination, not so?
Brandt Theunissen
2007 Mercedes Benz ML500 5.5
1968 VW Beetle 2276
Johan Maree
Isuzu 300 d-tec
Conqueror UEV-25
Here an article from Carmag explaining the above issues.
https://www.carmag.co.za/technical/t...-the-law-says/
On news24 yesterday (Dstv) they reported that the authorities are also clamping down on vehicles with ''modifications''.
Estee = S T = Sean Towlson
Hummer H3 V8
W.A.P Objectivist
Johan Maree
Isuzu 300 d-tec
Conqueror UEV-25
So in my simple mind I would have thought maybe just a fine, but then I thought a bit further.
If you are towing the trailer illegally, then the problem is the tow car plus trailer. Since the car on it's own is fine, they can't really take the car, but since the trailer combination is the problem, they probably deregister it so that you cannot just continue on?
2011 Freelander 2 SE
