Results 1 to 20 of 23
    Tshwanetoria
    Thanked: 1019
    Default Alternator wear and tear
    Does a second battery place additional load and thus additional wear and tear on a vehicle (smart) alternator?
  2. The Following User Says Thank You to hatjohan For This Useful Post:
    Wartburg.
    Thanked: 705
    Default Re: Alternator wear and tear
    I wouldn't say so, it is working the whole time, doesn't matter if there is one or two batteries connected, it's running.
    But I'm by no measure an auto electrician, just a guess.
    Toyota Land Cruiser 79 DC V8
    Toyota Hilux 2.8 GD6 4x4
    Toyota RAV-4 2.2 D4D
    ZS5CL
    Oct 2018
    Magaliesig
    Thanked: 592
    I look forward to this discussion as I have the same question.
    I believe it does place some additional load which is why I have completely separated my second battery from my vehicle electrics and only plan to charge it from solar panels.
    My analogy would be that if you had a trailer permanently hanging off your tow bar, that must place some extra load on your engine and gearbox over time?
    Rob Kirk
    Amarok V6.
    Sym 200 scooter 2 x 1, CVT transmission, 4V OHC, 11.4 kW, 15NM
    0-60km/h in about 10s (downhill), Top speed - 100km/h (on a steeper downhill)
    Ground clearance : 125mm on 16-inch rims
    Tare : 134kg, GVM : 250kg (approx), GCM : 250kg (approx), Towing capacity : 0kg
    Best of all : 4L/100km, town driving and pinning it...
    Oct 2012
    Thanked: 104
    As mentioned before. It’s running the whole time, so don’t really think a second battery wears on the alternator. What’s does is driving short distances. So be kind to your alternator , keep that crank battery charged up
    King Williams Town
    Thanked: 1565
    Not an expert but when having a dual battery system, you install one of those fancy solinoid systems that switches over from primary to secondary battery when traveling. What kills an alternator is excessive continuous heavy current draw off the battery.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  7. The Following User Says Thank You to hunter26 For This Useful Post:
    Apr 2018
    RSA
    Thanked: 1768
    Hi Hatjohan, any extra load placed on any machinery results in more wear. Extra load on an alternator will result in more heat generated as well. The components that will wear faster due to extra load will be the brushes, slip rings, bearings and belts. The diodes and windings can be affected if overloaded.
  9. The Following 3 Users Say Thank You to Olyfboer For This Useful Post:
  10. #7
    Thanked: 17104
    Quote Originally Posted by Gothan View Post
    Not so true on the new ones I think.
    Jakes Louw
  11. #8
    Thanked: 805
    I have zero knowledge on smart alternators. Old style I would say it is no problem as the windings in rotor and stator as well as diodes are designed to provide the output. With many alternators now providing 120A it would not take a long time of high current to charge both batteries and then the load is small.
    To think about extra wear on engine and gearbox because one might be using 1.5kW (when 100kW+ is produced by the engine) via the alternator to me is pie in the sky. Alternators have a cooling fan via the pulley to assist heat generated. Further the multi groove v belts should also not suffer too much due to the short term nature of charging.
    As already said if one had to draw 100A all the time to power a load then one can consider higher wear rates.
  12. The Following User Says Thank You to ekkekan For This Useful Post:
  13. #9
    Wilderness
    Thanked: 1409
    As the amperage demand increases the mechanical load increases. More rotational force is then needed. Thus, more kilowatts is drawn off the engine, increasing fuel consumption. If the amperage demand is higher than the designed output, damage will occur (burnt windings/rotor) The higher the Mechanical load on the alternator, the more the wear on bearings and brushes etc.
    Then contrary to all my statements above. There are thousands of vehicle out there with dual battery systems, some with fancy thingamajigs, and lots with a solenoid and a switch, which are happily serving their owners without a problem.
    Pieter Kemp.
    2011 Isuzu 300d-teq 4x4 d/c
    Home built Blapsie caravan.
  14. The Following 3 Users Say Thank You to Pieterk For This Useful Post:
  15. #10
    Tshwanetoria
    Thanked: 1019
    Yes, I am not concerned about and my question was not related to wear and tear on the engine/gearbox.
    But you confirmed my suspicion about the additional work load on the alternator
    Like all vehicle components, it also only has a certain service life (think water pumps and timing belts). So the reason to my question was that should an alternator not receive additional attention, given the extra load imposed by an additional 2nd (or even 3rd) battery. Given the fact that if that component packs up in the bundus, you are stuffed in more than one way? And also given the fact that it can be reconditioned quite easily and cheaply (by yourself if you are able), say at 100k? as a preventative measure.
  16. #11
    King Williams Town
    Thanked: 1565
    To lessen the load and help prevent premature wear and tear, use a solinoid to switch charging from primary to 2nd battery ie alternator only charges one battery at a time.
    IMHO if going on a long far away adventure and you worried about parts breaking or failing. I would get the starter and alternator serviced before the trip.
    215/80/R15c tyres
    GPS,Bluetooth
    snorkel soon
    Craig
  17. The Following User Says Thank You to hunter26 For This Useful Post:
  18. #12
    Jul 2010
    Pinetown
    Thanked: 2071
    From own experience more than once, alternators do and can fail even using a solenoid system when powering dual aux. batteries as well as the crank battery up front.
    To be fair though we have two 100 AH batteries in the back as well as the 90 AH crank.
    Probably a good idea (although I never did) to carry a rebuilt alternator with you as spare if overlanding in remote areas.
    You might never need it, but when you do ........
    See my Kokerboom report from 2018 where McGyver (Forum member travelling with us at the time) utilised out solar panel on the Isuzu canopy to power the vehicle when the alternator failed totally.
    We drove all the way from Keetmanshoop back to Pinetown on solar power - the first and maybe only, Isuzu Prius.
    EISH !
    Last edited by Peter1949; 2020/12/18 at 11:12 AM. Reason: Forgot to add Eish, Eish!
    Peter Hutchison
    Platkar = Chevy Spark 1.2
  19. The Following User Says Thank You to Peter1949 For This Useful Post:
  20. #13
    Oct 2018
    Magaliesig
    Thanked: 592
    Which reinforces my decision to use only solar to maintain my aux battery. I can plug my fridge in to the 12 V port in the load bin and drive on days when there is not enough sun for charging.
    OTT? Maybe, but that’s just me...
    Rob Kirk
    Amarok V6.
  21. The Following User Says Thank You to Ama-newbie For This Useful Post:
  22. #14
    Thanked: 17104
    I reckon in my limited electrical logic brain, that it depends on the Amp rating of the system. If your alternator is a low amp rating, it will work its bum off to charge 2 batteries. In which case, yes, it will experience more load hence more wear.
    Jakes Louw
  23. #15
    Ellisras
    Thanked: 916
    Excessive heat kills an alternator. The cooling fan inside the alternator needs to be able to do its job. For that it needs revs. So drawing high amps is not really an issue at decent cruising speeds. BUT, if you are crawling difficult terrain or driving very slow on game drives you are in potential danger burning it. On most vehicles the alternator runs at approx twice the engine revs.
    Many moons ago I have burnt my stock alternator on my 4.2D Patrol when it was directly connected to a total of 300Ah batteries during a long slow speed crawl (6 hours in 1st and second gear! up in Northern Moz). Luckily got hold of an el cheapo 2nd hand Lucas universal 60A off a scrapped farm tractor.
    That tought me a lesson.
    Since then I use decent DC-DC chargers which limits the peak amps drawn.
    Don’t blame yourself over past mistakes. It’s like driving down the N1 while looking in the rear view mirror only.
    2000 Patrol GU 4.2D(onkey) "old-timer" and wise at 854 000 km
    2014 Patrol GU 3.0CRD "teenager" in puberty at 121 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" at 125 000 km
  24. The Following 3 Users Say Thank You to Dungbeetle For This Useful Post:
  25. #16
    Nov 2020
    Ongata Rongai
    Thanked: 33
    As far as I understand it the following is true for alternators:
    • They will only output the current that is demanded by the load. I.e. the load sucks power, the alternator doesn't push it. (This is true for all charges/MPPT/alternators)
    • Alternator will really only provide half its rated output amps due to inefficiencies in the form of heat.
    • Extended high loads (i.e. drawing 50% of the rating continuously) for long periods will toast the alternator. Beware charging lithium batteries, see https://www.youtube.com/watch?v=jgoIocPgOug
    • The higher the load, the more heat. The more heat, the shorter the lifespan
    Alex
  26. The Following 3 Users Say Thank You to kavirondo For This Useful Post:
  27. #17
    B-gowrie Randburg
    Thanked: 355
    Charging a second battery and all other electrical junk in your vehicle all contribute to the net load call on your alternator ... all energy that has to be generated.
    I think the relevant aspect is the load call relative to the amp rating of your alternator ... where the former approaches the latter tolerances are tested and I would expect it to manifest esp in winding temp.
    Copper windings make alternators expensive items and manufacturers
    continually economise ... use thinner windings and fit lower rated alternators as they can get away with for
    point of sale.
    As for alternators breaking down ...
    it helps if you can crank start your
    motor ( pushing or even with a rope on your wheel etc!) and if you have a mechanical fuel pump ...
    ... say no more ... !!!
    2002 Defender 130 DC HCPU. :
    Own the road... Any road ...
    ‘1981 R-Rvr Classic 2-Dr 3.5L V8 :
    The Greatest Rover.
    ‘1975 Series3 88 PUP :
    Simply ... Classic ...
    ‘2017 Metalian Mini ...
    A Home from Home
  28. #18
    Thanked: 805
    Interesting topic. Although I doubt the 2nd battery will affect the alternator to worry about. The copper and laminated core of rotor and stator will not degrade purely because it is working. If concerned then just use a DC - DC charger that limits the current to 20-30A and you go. Essential as pointed out when using lithium.
    The weak points on the alternator is rectifier. It goes clamps when welding on the vehicle without disconnecting the battery. Vibration due to loose mounting bolts. Regulator as the components have a shorter life than copper. Bearings and more so on higher revving petrol engines as the alternator spins 2 to 3 times the speed of the engine. Brushes can also wear out but cheap to replace.
    I would guess the alt works harder after starting a car than it would when a 2nd lead acid battery is connected that is at 50% DOD.
    Many alternators work for 20years and may just need a regulator and bearings replaced. Then on tractors they vibrate a lot due to loose bolts and can give problems within 6 months. My experience years ago.
  29. The Following User Says Thank You to ekkekan For This Useful Post:
  30. #19
    Thanked: 208
    I totally agree with this.
    Weak points on alternators are the rectifiers , brushes, voltage regulator and bearings. Heat from overcharging or alternator being on the "hot" side (close to exhaust manifold) can also kill alternators. I've replaced all at times, and within a relative short time too. Getting the pulley off is usually the biggest issue.
    If you always have the dual batteries connected, I'd recommend that you use a DC-DC charger between the alternator and aux batteries as others have also noted.
    Thys de Wet
    Jimny 2009
    Ek het nou klaar gewerk, maar ek weet nie of die bank daarvan gaan hou nie...
  31. The Following User Says Thank You to dewets For This Useful Post:
  32. #20
    Wartburg.
    Thanked: 705
    Or just don't drive your vehicle, don't even start it, that way nothing will wear.
    ZS5CL
  33. The Following User Says Thank You to Chris8d For This Useful Post:
