Results 1 to 7 of 7
    Sep 2012
    Thanked: 9
    Default 2017 Isuzu 4x4 problem
    Hi Guys
    Please advise if any of you experienced this before and what is the solution to the problem.
    When engaging into 4H & 4L it engage immediately BUT the 4H & 4L dashboard light keeps on flashing - as we all now the light should indicate that you are engaged and should not be flashing.
    Just keep in mind the 4x4 system works and engages perfect.
    Ballito
    Thanked: 1353
    Default Re: 2017 Isuzu 4x4 problem
    Start with hard reset - uncouple battery for 30 mins.
    Jaco Nell
    Sep 2012
    Thanked: 9
    Thanks I'll try.
    Thanked: 84
    Werner, does it keep on flashing even after driving for a couple of meters?
    On my 2007, it also flashes until I start moving forward or reverse. It is as if there is a sensor that needs to align to confirm engagement.
    Jaco
    Isuzu KB300 DMax D/C 4x4 3" Homemade lift, Bosvark LFR Radio and free-wheel hubs.
    Apr 2011
    Thanked: 64
    Quote Originally Posted by jp_bez View Post
    I'd start looking for that sensor, sounds like it's gone bad if you say the mechanical bits work and your car has gone into low range.
    '14 Isuzu KB300 4x4
    '98 Defender 90 TD5
    SOLD: '02 Mitsu Colt V6 4x4
    SOLD: '97 Mitsu Pajero V6 GDi SWB
    SOLD: '08 Audi A5 3.2 Quattro
    SOLD: '07 Audi A4 2.0 TDI
    SOLD: '04 Mazda RX-8
    Sep 2012
    Thanked: 9
    Keeps on flashing.
    Jul 2010
    Pinetown
    Thanked: 2217
    My old 280 also started with that indicator flashing, byt 4x4 and low range is working.
    I think it would also be either the bulb in the display oe a connection issue or maybe the sensor.
    Mine no longer indicates at all but I can still engage and use 4x4 and low range.
    My old lady is much older than your old lady, but could be a similar issue.
    At this stage, as long as the mechanicals still operate as they should, I am happy.
    I can hardly see that indicator light in bright sunlights conditions anyway, and if you forget to disengage 4x4 it WILL remind you as soon as you start doing turns on a solid surface.
    For the rest you just waste some fuel.
    Then there is the diff. lock. So seldom used these days ....
    Peter Hutchison
    Platkar = Chevy Spark 1.2
