Start with hard reset - uncouple battery for 30 mins.
Hi Guys
Please advise if any of you experienced this before and what is the solution to the problem.
When engaging into 4H & 4L it engage immediately BUT the 4H & 4L dashboard light keeps on flashing - as we all now the light should indicate that you are engaged and should not be flashing.
Just keep in mind the 4x4 system works and engages perfect.
Jaco Nell
Thanks I'll try.
Werner, does it keep on flashing even after driving for a couple of meters?
On my 2007, it also flashes until I start moving forward or reverse. It is as if there is a sensor that needs to align to confirm engagement.
Jaco
Isuzu KB300 DMax D/C 4x4 3" Homemade lift, Bosvark LFR Radio and free-wheel hubs.
'14 Isuzu KB300 4x4
'98 Defender 90 TD5
SOLD: '02 Mitsu Colt V6 4x4
SOLD: '97 Mitsu Pajero V6 GDi SWB
SOLD: '08 Audi A5 3.2 Quattro
SOLD: '07 Audi A4 2.0 TDI
SOLD: '04 Mazda RX-8
Keeps on flashing.
My old 280 also started with that indicator flashing, byt 4x4 and low range is working.
I think it would also be either the bulb in the display oe a connection issue or maybe the sensor.
Mine no longer indicates at all but I can still engage and use 4x4 and low range.
My old lady is much older than your old lady, but could be a similar issue.
At this stage, as long as the mechanicals still operate as they should, I am happy.
I can hardly see that indicator light in bright sunlights conditions anyway, and if you forget to disengage 4x4 it WILL remind you as soon as you start doing turns on a solid surface.
For the rest you just waste some fuel.
Then there is the diff. lock. So seldom used these days ....
Peter Hutchison
Platkar = Chevy Spark 1.2
