Results 1 to 10 of 10
    Jul 2007
    Question V8 starting issue - click click
    I have a 2010 V8 HSE, the best Disco I have owned. I love this car big time.
    He, my vehicle is a he because he is strong and fast ;-), recently started have starting issues.
    Press the starting button, he goes through the sequence and then when pressing again it just makes the click sound. It sounds like a relay switching but not kicking the starter motor in.
    Sometimes I go through this sequence 3 or 4 times and then he starts.
    He will have no problem for 2 or 3 weeks and then all of sudden does it again.
    I was away and left him at home for 3 weeks and the issue was there again.
    At first I thought it was the battery but recently after a 2 hour drive he did it again.
    Alternator has been checked by my indie, all charging ok..
    How does one check the battery proper?
    Or any advice what else it could be?
    Thanked: 208
    Default Re: V8 starting issue - click click
    Next time it does it try and depress the brake pedal a little deeper/harder
    2005 Land Rover Discovery 3 V8 (Will allways end up with an V8)
    1999 Land Rover Discovery 2 V8 (Another one)
    1967 Land Rover Series 2A 3.5 V8 (The Green Machine)
    196? Land Rover Series 2 V8 100" (The Coiler)
    2010 Mercedes C350 CDI (The Daily)
    Ex.
    Discovery 1:TDI and a V8. Discovery 2 V8. Discovery 3 TDV6. Freelander 2 TD4, a C350 CDI and a Subaru Forester XT
    Garsfontein
    Thanked: 1495
    I presume that is still the original starter motor. Have the brushes and solenoid checked. Presume solenoid will be OK (the click, click), but the brushes are probably shot.
    Ian de Villiers
    Nissan Patrol GRX 4.5
    Thanked: 1352
    Start with your battery first.
    Take it to proper place, with decent testing stuff ,they can tell you. I use Minty's for that, though I don't know the places around you. You want one of those computerised testers. They tell you a lot.
    Chances are though it's your battery.
    O wait, sorry, I am such a liar. Your car is totally broken, and not worth fixing ,I'll take it off your hands for you though
    2011 Freelander 2 SE
    Jul 2007
    Quote Originally Posted by JeandreDiedericks View Post
    Thanks Jeandre, yes I know about the switch on the brake pedal, tried that, did not work..
    Feb 2017
    Ezulwini
    Thanked: 34
    Quote Originally Posted by Wiv View Post
    I.8svnw54sc95adi
    Jul 2010
    Pinetown
    Thanked: 2190
    Does the relay "chatter" or just "click - click" ?
    Hope you understand my question.
    If chattering then it usually means low voltage and if given a rest or using a different barry it would start.
    Driving a very old vehicle myself I keep a second (old) fully charged battery with me in the vehicle "just in case".
    Peter Hutchison
    Platkar = Chevy Spark 1.2
    Oct 2012
    Thanked: 508
    Check the easy stuff but do not discount the starter motor. On my 300Tdi (ancient history) I went through about 2 years of hard starting even after replacing the starter motor by an indy, but that none of the subsequent services could fix (the starter motor is a bugger to get out). Eventually it packed up and the auto electrician said it was a botched job from the first replacement. Just maybe.
    Joburg
    Thanked: 358
    My RR did the same. It turned out to be the starter. I removed and fitted it myself and paid R1650 for the recon/solenoid in 2016.
    Discovery 3 V8 HSE
    Defender 90 2.8i
    Audi SQ5 Tdi
    Range Rover 4.4 V8 sold
    Audi A3T sold
    Forest Hills, KZN
    Thanked: 989
    check battery charge
    brake light switch
    starter motor
    those are the 3 culprits I found for the same issue.
    2004 LR Discovery 2 Td5 GS - Hybrid Turbo, Intercooler, 33's, 2" Lift, V8 TC, Ashcroft CW&P 3.75 + ATB lockers. [GoldiloX]
    2003 LR Discovery 2 Td5 ES - Lots of Mods(check thread) - [Husky]
    2010 LR Discovery 4 V8 HSE - Lifted with IIDtool, Powered by Petrol and Running on Cooper AT3 LT (new spec) 265/65/18s [Imvubu] - SOLD
    Youtube Channel <-- Click Here
