Results 1 to 20 of 34
Thread: ZF & Dr Tranny
    Feb 2012
    Brackenfell
    Thanked: 46
    Default ZF & Dr Tranny
    So it's been a fairly mundane weekend. So armed with the attached fluids, a clean oil squirt can and some time.
    I removed the top oil cooler feeder hose next to the radiator.
    With my previous disco 3 I squirted the additives into the radiator but this time around RR Sport - and since the red Viennas has shrunk ( I don't recall these being so tiny) I could put all in the oil squirter with ATF protectant
    I took about 53 squirts and I was 80% done.
    The rest of the additive mix was put into a big syringe and I could empty that 100ml into the feeder pipe.
    All clamped back and now for the road test.
    NB 6000km ago I did new sump and life guard oil.
    This additive and shudder fix are merely preventative measures.
    2x Dr Tranny shudder fix
    1x Lubegard Platinum ATF Protectant
ID:	436853Click image for larger version.
ID:	436854Click image for larger version.
    2009 Range Rover Sport 4.4 V8 HSE (his)
    Izmir Blue
    2012 Audi S3 (hers)
    Brilliant Red
  2. The Following 2 Users Say Thank You to JacquesC For This Useful Post:
  3. #2
    Gaborone
    Thanked: 1234
    Default Re: ZF & Dr Tranny
    Nice job!
    1997 Discovery 1 300tdi - Pussy Galore
    1996 Discovery 1 V8 - Mr Creosote
    Tzaneen
    Thanked: 433
    Will watch the result with interest
    Frans
    2012 RR TDV8 4.4
    2006 TDV6 SE A/T(Sold)
    2008 FL2 TD4 SE A/T
    1968 Renault 8 Gordini
    Thanked: 95
    Well done.
    I was thinking the other day, our Merc w169 A180 auto has a bit of a shudder every now and then- wonder if Dr. Tranny would do the trick on the cvt gearbox??
    2009 Defender 110 puma SW
    2011 Freelander 2 SD4 (Swambo)
    1999 Defender 90 2.8i
    1966 Series 2a 88'' 2.25 petrol - ALFIE
    Ex:
    2010 Discovery 4 V8
    2007 Discovery 3 V8
    2008 Defender puma 110
    2003 Discovery 2 td5
    2000 Defender td5
    Thanked: 95
    Deleted. Double post
    Ex:
    2010 Discovery 4 V8
    2007 Discovery 3 V8
    2000 Defender td5
    Feb 2012
    Brackenfell
    Thanked: 46
    Ok, after about 65km,
    I'm VERY happy to report that the ZF Tranny has become even smoother, outside temp is about 33 deg C and the box behaving exceptionally well.
    Up shifts are a lot better, with time taken to upshift, downshifting has particularly become "unnoticed"
    Remember with the fresh oil and new sump / filter things were already smoother . . .
    This additive -- WHAT EVER IT DOES OR WHATEVER IT IS SUPPOSE TO DO -- has just made this ZF box better.
    Will keep this updated and will sit in CPT N2 traffic this afternoon and will definitely get a feel from the clutches and their 'new found' life . .
    Izmir Blue
    2012 Audi S3 (hers)
    Brilliant Red
  8. The Following User Says Thank You to JacquesC For This Useful Post:
    May 2014
    Kenridge
    Thanked: 98
    Quote Originally Posted by Champ View Post
    Well done.
    If it's a chain drive (like the Audi) I would be very careful as the CVT oil has the property to harden under pressure to enable chain on metal drive and only if Dr T will support that will it work.
    2005 Disco 3 TDV6
    Thanked: 128
    Few quick questions:
    1. How did you manage to get everything in the transmission via the pipe. i tried it, but pipe filled up so quickly, could hardly get 1 tube of tranny fix in there...Was it done under pressure ?
    2. Did you have the transmission adaptive values reset after the oil flush. I've been told it must be done after an oils change, transmission repair or Torque converter change.
    2009 D3 V8 SE - Family car, holiday and weekends
    2009 Mahindra Scorpio 2.6 GLX - Mom's Taxi
    2001 Ford Ranger 2.5 D/C - My Car
    2007 D3 TDV6 S - Family car, holiday and weekends ( RELUCTANTLY SOLD )
    Mar 2013
    Thanked: 82
    Ja, I also struggled to get 1x tube in the pipe. Anyone adding Dr.Tranny should take out plenty of oil first! But yes, Dr. Tranny eats up those shudders and smooths out the gearbox.
    ''​Luck favours the prepared man''
    '14 Jeep Grand Cherokee Limited - 3.0 CRD [Geolander AT G015]
    [FR Slimline II Roofrack]
    Discovery 3 HSE - 2.7V6Tdi 2008
  12. The Following User Says Thank You to Naguiltjie For This Useful Post:
  13. #10
    Feb 2012
    Brackenfell
    Thanked: 46
    Quote Originally Posted by AllOutdoors View Post
    Ok chaps some context.
    my Rangie was parked overnight and stood for two full days.
    I squirted all in one operation both (little) tubes AND platinum additive into the top hose which on the V8 is apparently the return feeder pipe. didn't have to wait for fluid to settle into the pipe. Honestly didn't have ANY issue feeding all thru this way, even that last bit with the syringe, maybe had to do with the Rangie being parked for two days that the return pipe was empty . . . . .
    Re Adaptation; this was all done when ZF did the flush and new sump in early Dec last year
    cheers
    JC
    Izmir Blue
    2012 Audi S3 (hers)
    Brilliant Red
  14. #11
    Strand
    Dr Tranny is amazing stuff. I had my ATF flushed, filter replaced and 2 x Dr Tranny added to my D3 at around 140 000km. The shudder returned recently (now at 180 000km) and I booked it in at another indie for flushing but without Dr Tranny. I was time pressed as the flush was booked for Wednesday and I was due to drive to Namibia on the Saturday and the shudder and TC slip had become quite harsh, so I was concerned, would this work or would I need to go to Nam in the far less comfortable bakkie?
    The day after the flush, the shudder was about 90% better but there was still quite a bit of TC slipping so I took it back to the indie and asked him to add 2 tubes of Dr Tranny - by this time I was getting worried that we wouldn't be able to make the trip in the disco and that I was in for a hefty bill for work on the transmission.
    Within kms of adding the Dr Tranny all was back to normal. We've just returned from a ~2600km trip to Namibia (500km on dirt roads) without incident. I am definitely going to buy some more of this stuff and also possibly the ATF protectant.
  15. The Following User Says Thank You to Riddim For This Useful Post:
  16. #12
    Jul 2008
    MTUNZINI
    Thanked: 659
    To fill from bottom is quite easy.
    Remove the guard
    Drive the vehicle on a ramp, , bricks or grass bank let it lean far over to one side, hell now I cant remember which side is the filler.
    Open up the level plug and squirt in, , works the quickest.
    Once again this red viena is AMAZING stuff
    Koos Best
    Land Rover Discovery3 TDV6 S.
    VW T5 D/cab 4 Motion with slide on camper
  17. The Following User Says Thank You to Koos Best For This Useful Post:
  18. #13
    Thanked: 128
    Quote Originally Posted by JacquesC View Post
    Jacques,
    Some feedback, How many miles done now and whats your verdict so far ?
  19. #14
    Feb 2012
    Brackenfell
    Thanked: 46
    Hey all I've done now about 10 000km give or take a few hundred Kms and have just praise for the ZF.
    The thing is after the oil change, there was no distinction between a cold and warm transmission, with the additives it's become even smoother.
    She behaves the same, early morning, during the day and those late nights when the foot is slightly heavier
    I would recommend the Dr Tranny AND the oil change (DONE PROPERLY) to ANYbody with a ZF box that has mileage on it.
    #NOT_Actually_filled4life
    My previous D3 diesel got the same TLC and the results were the same and I sold around 195000km without issues!!
    Go and do it in conjunction with fresh oil
    Just a word of caution this was more preventative for me. The oil change and the Dr Tranny will not 'rectify' any mechanical issues already experienced.
    JC
    Izmir Blue
    2012 Audi S3 (hers)
    Brilliant Red
  20. The Following User Says Thank You to JacquesC For This Useful Post:
  21. #15
    May 2012
    Thanked: 180
    Where do I buy Dr Tranny please!
    I am having the gearbox oil changed soon in my D3 and it seems to be right thing to add.
    Thanks,
    Rob
  22. #16
    May 2014
    Kenridge
    Thanked: 98
    DR TRANNY SHUDDER FIX LUBE ⋆ British 4x4 Components
    https://www.british4x4.co.za/product/dr-tranny-shudder-fix-lube/
    DR TRANNY SHUDDER FIX LUBE. R210.00. 13 in stock. Add to cart. SKU: 19610 Category: New. Reviews (0). Reviews. There are no reviews yet. Be the first to review “DR TRANNY SHUDDER FIX LUBE” Cancel reply. Your email address will not be published. Required fields are marked *. Your rating. 12345. Rate…
    2005 Disco 3 TDV6
  23. The Following User Says Thank You to georgecape For This Useful Post:
  24. #17
    Thanked: 1536
    What is the principle/active ingredients that make this stuff work so well?
  25. #18
    May 2012
    Thanked: 180
    Just a heads up.
    I bought Dr. Tranny for R180 a tube plus R99 Postnet charge from Brian.
    [email protected] - he lives in Slaaapstad.
  26. The Following User Says Thank You to Onematch For This Useful Post:
  27. #19
    May 2016
    Thanked: 38
    Stupid question, but would this still be effective if i do the oil change and service at ZF and then have my indy add the DR Tranny with the next visit a week or 2 later?
    Or do they have to both go in 1 shot?
    2006 Land Rover Discovery V8 SE (Sold to DD, then bought it back again) Boomerang
    2018 Ford Ramger D/C 2.2 TDCI 4x2 XL Auto (Company car)
    2014 Ford Ranger D/C 2.2 TDCI 4x2 (Company Car) Retired
    2013 VW Polo 1.6 (swambo) SOLD
  28. #20
    Jul 2016
    Thanked: 623
    you can add the Dr Tranny whenever you want
  29. The Following User Says Thank You to MikeBob For This Useful Post:
