Results 1 to 10 of 10
Thread: Turbo boost psi
    Kimberley
    Thanked: 249
    Default Turbo boost pressure
    How much boost is too much.
    For pajero Gen2 2.8
    At max boost it reads 0.7 bar not sure how accurate the meter is
    I'm thinking it is a bit high
    What do you think. Should I find a way to get it down a bit
    Pajero Gen2 1996 2.8TDi LWB
    Ellisras
    Thanked: 1432
    Default Re: Turbo boost pressure
    Quote Originally Posted by hogbeast View Post
    For pajero Gen2 2.8
    1996 2.8....hmmm - Did your model have an Intercooler fitted as original ? If so, 0.7Bar does not sound to high...
    2014 Patrol GU 3.0CRD "teenager" in puberty - 131 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" - 125 000 km
    Krugersdorp
    Thanked: 1055
    Default Re: Turbo boost psi
    I believe the max boost pressure for a standard 2.8 Gen2 Pajero is around 14PSI which equates to around 0.9bar.
    0.7bar sounds fine on a standard engine.
    Thanked: 20097
    0.7 bar is low. 16PSI = 1 bar
    Jakes Louw
    Ellisras
    Thanked: 1432
    16PSI - or are you just teasing us ?
    1 Bar = 14,5038 PSI
    Thanked: 20097
    1 Bar = 14,5038 PSI
    Hey I worked on memory, not Google. Give an old man a break.
    Jakes Louw
    Kimberley
    Thanked: 249
    Ok. I will leave as is then. It only runs max boost in extreme cases anyway which is not often
    Thank you
    Friemersheim, Southern Cape
    Thanked: 5427
    Nope
    Robert van den Berg
    '98 Daihatsu Rocky 'The Kitty'
    '02 Daihatsu Rocky 'The Bully'
    Thanked: 20097
    Nope
    Eish it's a tough crowd tonight
    Jakes Louw
    Langs die rivier, op n berg
    Thanked: 4547
    Hoeveel boost is te veel?
    Wat word beskou as baie boost?
    Nog n vragie: veronderstel brandstof beskikbaarheid is nie n probleem, beteken dit dan n 2 liter teen 1 bar is gelyk aan n 3 liter non turbo, en n 2 liter by 1.5 bar is gelyk aan n 4 liter non turbo?
