Results 1 to 20 of 26
    richards bay
    Default solar panel frame build..
    hi i got to build solar panel frames for my roof its gona be a fix tilt.. got a question on size of material i should go for . each fram will holes a 345w panel but want to make it for 410w incase the future changes.
    so stainless is expensive but dream to work with and no rust coating needed
    Aluminum i cant weld have to bolt it but no rust coat needed
    then there is steel that after fabricated it i goto galv it.
    asking for those people you has build them before and learned which is better
    and size of metal needed i can calculate the lengths
    Jan 2017
    Jhb
    Thanked: 47
    Default Re: solar panel frame build..
    Just buy a mounting system from any of the major solar suppliers.
    They bolt together, no welding etc.
    Anders Boden
    Thanked: 17902
    Also looking at this and I'd say riveted aluminium would be cheapest and fastest and lightest.
    Adding panels to your roof is bad enough: adding extra frame weight might not be ideal.
    Jakes Louw
  4. The Following User Says Thank You to jelo For This Useful Post:
    richards bay
    it goth last 25years with the winds and all that.. i got monkey's so that's an extra factor i goto put in
    Thanked: 1035
    This extrusion in pic will work fine. Allow the extra 50mm in width and 100mm in length for the bigger panels. As the mounting in length is not at the end of the panel just allow for the extra width. Click image for larger version.
  7. The Following User Says Thank You to ekkekan For This Useful Post:
    Thanked: 17902
    Quote Originally Posted by 519franco View Post
    @ 25kg each per panel excluding the frame, you really should check your roof construction.........
    Jakes Louw
  9. The Following 2 Users Say Thank You to jelo For This Useful Post:
  10. #7
    Brackenfell
    Thanked: 509
    Connect-it with 25 square tube. and rivet some angle to tubing frame which will hold the panel. Rivet/bolt panel to angle iron.
    Hinges on the one side of the frame and drop locks to keep down during travel
  11. #8
    richards bay
    boet for the house not a camper.. but that plan ill work perfect for that application
  12. #9
    richards bay
    roofs construction is 100%.. only downside is that we got slate tiles not the those ordinary tile so attaching to the roof is fun but i got plans to do that with hout drilling many holes but i was asking to get material sizes of what people are using .. so I don't over build it as I do with everything else.
  13. #10
    richards bay
    All iam asking is the materials and size off material so I can work out the price for me to build the fix tilt panel stand.. if its to expensive and wont see my gains ill have it none tilted and fix it 100mm off my roof..
  14. #11
    Thanked: 1632
    Download the brochure from Rubicon, there are many options for exactly what you want.
    https://www.dropbox.com/s/sjwhl4wene...ories.pdf?dl=0
    Padraic Berry
  15. The Following User Says Thank You to NewLandy For This Useful Post:
  16. #12
    richards bay
    perfect thanks
  17. #13
    Feb 2013
    Thanked: 1622
    If you carefully calculate all material cost not forgetting accessories and consumables, then the ready made mounting systems on the market is not that expensive at all.
    Plus should structural COC, insurance compliance etc. ever come in to play, you'll be much better off with professionally designed and manufactured mounting systems.
    "The problems we have today is because the guys who work for a living are outnumbered by those who vote for a living." - Magnus Heystek
  18. #14
    Hillcrest
    Thanked: 8402
    Exactly. This industry is now quite mature and there are purpose designed and made extrusions and fittings that really are easy and nice to use. Boer maak n plan solutions can cost just as much in the end and come back to bite you in the long run.
    Slate tiles I have done two installations.
    1/. Slate is removed where the panels go. Pic's attached. (Before and after)
    2/. Slate stays in place and holes are drilled in the slate. Pics attached. (the 5x3 arrays)
ID:	597752   Click image for larger version.
ID:	597753   Click image for larger version.
ID:	597754   Click image for larger version.
    ZS5KAD
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
    A V6 and an inline 4
  19. #15
    richards bay
    thanks.. I got east and west facing roof should I tilt it to the north?
  20. #16
    Krugersdorp
    Thanked: 209
    East west works nice for home/residential use.
    Riaan
    2019 Toyota Land Cruiser 200 GX-R
    2019 Toyota Hilux Extracab 2.8GD6 4x4
    2018 Bush Lapa Ratel 4 (B1244)
  21. The Following User Says Thank You to Monkey-D For This Useful Post:
  22. #17
    Feb 2012
    Thanked: 16
    I recently put up 6 x 330w panels (2mx1m), on a flat roof, I used 30x30x2.5 angle iron,,,with enough support/gussets sections I think I used 7x 6m lengths...lets say it's 6kg /length overall combined weight of the complete setup average 180kg that is spread out on 10sqm. I did keep the strength of the roof structure in mind and in the middle of the roof the wood beam rests on a wall - so that is the solid point - I worked from that as the frame lies with its center point on that beam, I further used anchor cables(electric fence cable) from each corner rawl bolted in brick wall - if the wind wanted to move
    In the past week we had a big storm with hail and the neighbor's 30 year old tree was blown over...my panels did not move,,,so I am happy.Click image for larger version.
  23. The Following User Says Thank You to Willem01 For This Useful Post:
  24. #18
    Thanked: 1632
    Quote Originally Posted by Willem01 View Post
    Very nice... I may move my panels in future, I just cant decide if its financially worth the extra few kWh of PV generated per month (estimate 10%) and my install will probably end up looking like yours.
    An issue arises when your panels do blow over, get damaged by hail etc. and you try put in an insurance claim. Then the structure is questioned, engineering signoff etc. At least with a purchased (and hopefully certified structure) one has some chance of winning the fight.
    Padraic Berry
  25. #19
    Kuilsrivier
    Thanked: 180
    If you not looking to use off the shelf mounting structures, use Unistrut.
    It is an approved mounting method for electrical equipment and is also galvanized, so should last a long time.
    The normal solar anti theft brackets also works great with these.
    When not mounting flush with the existing roof, please also look at wind loading.
  26. The Following User Says Thank You to Wetkit For This Useful Post:
  27. #20
    Krugersdorp
    Thanked: 209
    Look at www.valsa.co.za for mounting structures manufactured locally.
    See below ground structure from them I installed this week for a borehole.
    I am not affiliated or get anything for mentioning them.
    Riaan
  28. The Following 3 Users Say Thank You to Monkey-D For This Useful Post:
