Unimog 416: Where can I find Hub Seals?
Results 1 to 9 of 9
    Nov 2020
    Default Unimog 416: Where can I find Hub Seals?
    Hello again everyone,
    The engine is running, now I'd like to move my Unimog to a more convenient location.
    I've read on this forum how crucial it is to replace the Hub Seals and that'll probably be my next step.
    Where would I be able to purchase hub seals for a 416? Or do they come in a size that's universal, that I could buy from anywhere?
    Any advice is greatly appreciated
    Thanked: 17104
    Default Re: Unimog 416: Where can I find Hub Seals?
    "Contact Ferdi at MogDoc +27 76 776 04 eight three for advice on this one." ?
    Jakes Louw
    Nov 2020
    I've attempted this route multiple times, to no avail. I'd rather get the process started while I wait for the professionals to become available
    Mar 2012
    Thanked: 4142
    We've got a customer that sources his Unimog parts from R21 Truck & Plant
    011 206 8958 but he advised to rather email them at [email protected]
    Pieter le Roux
    Nov 2020
    Quote Originally Posted by Redman View Post
    Thanks Redman - I've sent an email
    Nov 2011
    Thanked: 200
    You can get them from MBSA.
    Call Sandown in Centurion and ask to be connected to Nardus.
    Make sure you seat them correctly. Pedantic buggers.
    Nov 2020
    Thanks Mogster!
    I'll give them a call tomorrow.
    I've heard they have to be inserted...perfectly. Any other tips for inserting them?
    Nov 2011
    Thanked: 200
    Never use a hamer or such thing to tap them in going around the seal.
    There is a special tool, looks like a big cup, seats it with pressure when tapping in, all around at once.
    Thing is, if it leaks after seating, it is stuffed. You can dump it in the bin.
    And leaking hubs can cause gear failure if going unchecked.
  9. The Following User Says Thank You to Mogster For This Useful Post:
    Nov 2020
    Aah thanks - I'll be on the lookout for a tool like that.
    Another thing - Are the hub seals for the front and the back the same?
