LiFePo4 -Which chargers
Results 1 to 8 of 8
    Oct 2012
    Thanked: 283
    Default LiFePo4 -Which chargers
    I am thinking of getting one of those 12V 120AH LiFePO4 DIY Kits. Now I have read that you should use the correct charger. Their response, "Best would be a charger that allows for adjustable bulk and float settings"
    Can you tell me which is the best suited/correct DC-DC and "garage" chargers to use on these products?
    That Mighty Amarok
    Swart Tires wat ek self gekoop het
    Pull over wat my ouma gebrei het
    Vensters waar deur ek kan sien
    Engine voor
    Exhaust agter
    Thanked: 17104
    Default Re: LiFePo4 -Which chargers
    I now almost nothing about the subject, but I'd say you need a proper intelligent Battery Charge Controller.
    Victron for example.
    I'm sure Ekkekan and the other bright okes will come along soon.
    Mar 2012
    Ballito
    Thanked: 329
    Quote Originally Posted by Snyks View Post
    I got the Victron TR Smart Blue blah blah so many words in the name 12|12|30 DC-DC charger. Perfectly happy with it.
    Chris
    ZS5CMA
    '17 Hilux 2.8GD-6 D/C 4x4 A/T
    Thanked: 871
    AFAIK you need specific LiPo compatible chargers, see eg https://www.instructables.com/Lithiu...mer-Etiquette/
    Risk of fire is real when using a wrong charger.
    Thanked: 1566
    Padraic Berry
  6. The Following User Says Thank You to NewLandy For This Useful Post:
    Nov 2008
    Thanked: 122
    I had done exactly the same with building my own batteries. My build is shown in a different thread here. What I opted for on the AC side was the Victron Blue Smart Charger 12/30 and on the DC side went for the National Luna DC-DC 40. Perhaps a bit over kill for your application and could go for the 15A or 20A Victron's and perhaps the NL 25A DC charger.
    Simplicity is the ultimate sophistication.
    - Leonardo Da Vinci
    Also on
  8. The Following User Says Thank You to Rooikop For This Useful Post:
    Oct 2012
    Thanked: 283
    Thanks all...I think I will also take the plunge
    That Mighty Amarok
    Engine voor
    Exhaust agter
    Nov 2008
    Ellisras
    Thanked: 841
    See posts #20 and #23 in this thread for some explanatory notes on charging LiFePO4 cells
    https://www.4x4community.co.za/forum...rtable-Battery
    Rudolf Ras
    Don’t blame yourself over past mistakes. It’s like driving down the N1 while looking in the rear view mirror only.
    2000 Patrol GU 4.2D(onkey) "old-timer" and wise at 853 000 km
    2014 Patrol GU 3.0CRD "teenager" in puberty at 117 000 km
    2007 Echo3 Trailer "the nest" Braked Axle fitted at +60 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" at 124 000 km
  11. The Following User Says Thank You to Dungbeetle For This Useful Post:
