Trans Botswana & Covid - Page 2
Results 21 to 37 of 37
    Tzaneen
    Thanked: 359
    Default Re: Trans Botswana & Covid
    Quote Originally Posted by Mueneni View Post
    Drove through Bots and it was quite seamless actually. Just have your covid test ready and you are good to go.
    Same here.
    Returned yesterday through Groblersbrug.Passed through one sone.Wanted to see passport/ID and covid test papers.....it was older than 72 hours,no problem.
    Border easy as there are hardly any travellers.Coming out needed Covid rapid test at ZA side as ours was older than 72 h.All in test and results took about 3h @ R170.The 14 day grace only apply to commercial travellers according officials.Coming out no covid problems at Bots side.
    2012 RR TDV8 4.4
    2006 TDV6 SE A/T(Sold)
    2008 FL2 TD4 SE A/T
    1968 Renault 8 Gordini
    Gaborone, Botswana
    Thanked: 1365
    BW Government say you are not allowed the charge more than BWP500 for a Covid test
    Diagnofirm say they cannot do it at 500
    Apparently Government Clinics can have the result in a day if you mention that you need it to travel across a border.
ID:	598898   Click image for larger version.
    Kobus
    Gaborone, Botswana
    Thanked: 1365
    Additional open borders from December 15
    Kobus
    Jul 2018
    Potchefstroom
    Thanked: 23
    I’m doing a trip to Zambia in Jan. If I understand these post correctly:
    It is possible to trans through Bots to get to Zam.
    I need a valid not older than 72hrs negative covid test.
    I can travel through Zones in Bots no problem.
    Coming back I can do a covid test at SA border.
    I would need to do a Covid test in Zambia though for Bots again?
    This is quite urgent for me and I need your input please.
  5. #25
    May 2018
    Randburg
    Thanked: 9
    Just came trans through bots today..you will need a test certificate for going and passing through the zones is not a problem if you manage to enter at the border. You will need another test certificate on your way back to gain entry and they are serious about the certificate
  6. #26
    Jul 2018
    Potchefstroom
    Thanked: 23
    Quote Originally Posted by Witness View Post
    Thank you for the info. Does Bots also take the certificate from report date or do they do date tested?
    Can a person take a test in Livingstone or is nearest Lusaka?
  7. #27
    May 2018
    Randburg
    Thanked: 9
    They do date tested and validity period of 5 days from date of sample taken
  8. #28
    Jul 2018
    Potchefstroom
    Thanked: 23
    Thank you
  9. #29
    Thanked: 14
    Hi. Has anyone been through borders this last week into Bots?
    Martin’s Drift or Parr’s Halt open?
    and queues at border?
    2014 Prado VX 3.0
  10. #30
    May 2018
    Randburg
    Thanked: 9
    Part's halt closed Martin drift is open but not sure of the queue condition. Kopfontein open and no queue at all
  11. #31
    Jul 2018
    Potchefstroom
    Thanked: 23
    Does anybody know if Ramatlabama border post is open?
  12. #32
    Jul 2009
    Thanked: 1073
    Quote Originally Posted by Kudus View Post
    As far as i know it is yes. We will transit through Bots tomorrow traveling from Buitepos in Namibia and leaving Bots at Ramatlabama.
    We should pass through Ramatlabama at around 2pm, will update if its NOT open.
    Toyota Fortuner 2.8 GD-6 4x4 Auto
  13. #33
    Jul 2018
    Potchefstroom
    Thanked: 23
    Quote Originally Posted by Caracal View Post
    Thank you very much!! Will appreciate the help and info. Safe travels!!
  14. #34
    Jan 2009
    Potchefstroom
    Thanked: 350
    It's open. Went through a week ago. There is a long queue for the screening at the SA side though as all the truckers get there early. It took in excess of 45min each time we went through.
  15. #35
    Jul 2018
    Potchefstroom
    Thanked: 23
    Quote Originally Posted by Sias View Post
    Great. Thank you!!!
  16. #36
    Jul 2018
    Potchefstroom
    Thanked: 23
    Quick question. I don’t know if I understand it correctly. Botswana requires PCR negative test for entrance but it says also to exit Botswana. Is the exit just for the other country or does Botswana want it in order for you to exit?
  17. #37
    Jan 2009
    Potchefstroom
    Thanked: 350
    They looked at it as we left as well, don't really know why. That's when I found out the lab put my common name (noemnaam) on the report, not my full names as in the passport! Make sure your full names and details are as per your passport.
