Barnie Hickman
Jeep XJ 95 "Witblitz" Jeep XJ 99 "Goldi" Swambo's
Does anyone have/use this First Ascent Supreme?
https://www.firstascent.co.za/supreme-mattress
David Vierra
‘21 Toyota Tacoma 4X4 3.5L M/T
‘52 Beech Bonanza
[QUOTE=BarnieH;4531410]Hi Peter, how does the Tentco packed dimensions compare to the Carmaquip?
The tentco is slightly bigger but only because the Carmaquip we had was 7cm thick and Tentco we changed to was 10 cm thick. This was a big improvement on our comfort. Although Tentco use a preferable type velvet (Carmaquip was a type vinyl) we still used a fitted sheet as we use the 2 x 10cm Tentco's side by side in place of the 10cm foam matress in our Echo Namib.
I would guess the 10cm Tentco packed is about 30cm in dia and the 7 cm Carmaquip about 220 cm in dia. The rest of the length packed size very similar.
Peter
SOMETIMES I WAKE UP GRUMPY,
That Mighty Amarok
Swart Tires wat ek self gekoop het
Pull over wat my ouma gebrei het
Vensters waar deur ek kan sien
Engine voor
Exhaust agter
This is the other big advantage of the First Ascent, it rolls up really small.
I had people laugh at me when seeing how "thin" the First Ascent is, but they change their mind quite quickly after having a lie down on it.
There is also quite a big difference between having to tolerate a mattress for only 2 nights in a row vs longer, the longest I have slepped on my First Ascent was 15 nights in a row.
Had 2 carma quips, good robust quality, however I did not find them so comfortable AND it is noisy. If you role over it might wake the person next to you. Something so small will become something very big if swambo did not sleep well.
2015 Duster 1.5 dci 4wd
I found that some people comment that they inflate the matresses orally. There is a large amount of moisture on ones breath and given that the matresses will be nice and warm probably a nice breeding ground for some ugly "bugs". Right now I am fed up with all the bugs and viruses we have to contend with
Peter
I don't know about the others, but with the First Ascent there is no need to add any additional air to it. I roll it out in my tent and open the 2 caps, leave it for a while then it self inflates like the name says and I close the caps.
If it has been stored rolled up for a long time or I'm in a hurry, then I give it a couple pumps with my hand or foot to allow it to suck in air more / faster, otherwise I'll just open the caps when I set up camp say late afternoon and then only close them when I go to bed tonight.
I believe that when asking for any mattress advice it is very important to know how much the person weighs that's advising you!
What might work for a 70kg hiker guy will not work for me, at 2m and 140kg, when camping!![]()
Conqueror Courage 2016
I forgot to store mine inflated.
It took a while for the foam to pop out again.
The Carma quip mattress material is hard, but then one must remember that the makers developed it for sleeping along the Orange river where stones, sticks and thorns can be harsh on the outside material.
Barnie Hickman
You can have 1. Cheap. 2. Strong. 3. Light.
Pick any two.
For strong and comfortable, Tentco.
For light, anyone of the others. So the question is where are you going and how are you planning to get the mattress there. If I'm going by car I take the Tentco. http://tentco.co.za/index.php/quick-...ss-10cm-detail
If I'm walking I take the Thermarest https://www.futurama.co.za/therm-a-r...waAhOzEALw_wcB
A dog has no use for fancy cars, big homes, or designer clothes. A water logged stick will do just fine. A dog doesn't care if you’re rich or poor, clever or dull, smart or dumb. Give her your heart and she'll give you hers. How many people can you say that about? How many people can make you feel rare and pure and special? How many people can make you feel extraordinary?
Couple of months ago we stayed at a tented camp and they had the Natural Instincts Heavy Duty Stretcher with the Campmaster 65 mm Fold-Up Mattress and we slept well.
We are used to the Carma Quip on the same stretchers but were pleasantly surprised with the Campmaster mattress.
Also look at Tentco's range of mattresses.
