Freelander II Tensioner Kit
Results 1 to 6 of 6
Thread: Tensioner Kit
    Nov 2020
    Default Tensioner Kit
    Hi All,
    I replaced my power steering pump on my freelander 2 yesterday. Pump is still a bit noisy. The mechanic said that the tensioner need replacement, hence the noise on the pump because of insufficient tension. It is currently on 144000km. Three things:
    1. please recommend a good tensioner kit
    2. Pls advise on the pump noise
    3. Can anyone recommend a good indie mechanic.
    Any help is most appreciated.
    Jul 2016
    Thanked: 568
    Default Re: Tensioner Kit
    It’s possible the filter in the steering reservoir is blocked causing the noise
    Nov 2020
    Thank you MikeBob. Will replace tomorrow and let you know.
    Nov 2020
    <br>Thank you MikeBob. Will replace tomorrow and let you know.&nbsp;
    Thanked: 246
    The filter cannot be replace on it;s own, it is part of the reservoir, but not overly expensive.
    Si vis pacem, para bellum
    Feb 2020
    Minneapolis and Las Vegas
    Thanked: 693
    Is the noise belt squeal, or cavitation from residual air in the oil?
    If the oil in the reservoir is frothy (common after opening up the system for repairs) the noise will settle down once the air is out of the oil...
    David Vierra
    ‘21 Toyota Tacoma 4X4 3.5L M/T
    ‘52 Beech Bonanza
