Results 21 to 40 of 41
    Apr 2017
    Middelburg
    Thanked: 26
    Default Re: WK Eagle Head 5.7 hemi
    https://drive.google.com/file/d/1Guk...ew?usp=sharing
    7000 page Service manual for the Grand Cherokee WK.
    In it you will find about a few 1000 pages of fault finding and engine codes.
    Engine systems starts at page 1437.
    Hope this helps Skala
  2. The Following User Says Thank You to Gerhard Hoffman For This Useful Post:
  3. #22
    Cape Town - RSA
    Thanked: 455
    Error Code P0513 means the PCM (powertrain control module, also known as ECM or engine control module in other vehicle makes) has detected the presence of the immobilizer key (better known as ignition key) but fails to recognize it. If the ignition cylinder is turned on, the engine is cranked (but not yet started).
    I would start by changing the battery in the keys/remotes.
    Ex - 2005 Cherokee CRD
  4. #23
    Mar 2009
    Fishhoek
    Thanked: 157
    Thanks, have done so. Will take Jeep to Kyle to check modules whilst connected to Chrysler/Mopar is US.
    Will give feedback
    2010 Eagle Head 5.7 hemi
  5. #24
    Mar 2009
    Fishhoek
    Thanked: 157
    Quote Originally Posted by Gerhard Hoffman View Post
    Thanks, I have a copy.
  6. #25
    Mar 2009
    Fishhoek
    Thanked: 157
    Still playing with the tune using HP Tuners.
    Started to fit the rock sliders taken off previous hemi.
    Some pics as promised. SRT 8 intake pipe, catch can, fire extinguisher, LED lights in back, towbar.
ID:	603741   Click image for larger version.
ID:	603742   Click image for larger version.
ID:	603743   Click image for larger version.
ID:	603744   Click image for larger version.
  7. #26
    Mar 2009
    Fishhoek
    Thanked: 157
    Removed skirting and fitted rock sliders and mud flaps
ID:	604004   Click image for larger version.
  8. #27
    Apr 2017
    Middelburg
    Thanked: 26
    How do they mount to the chassis?
  9. #28
    Mar 2009
    Fishhoek
    Thanked: 157
    There are already 6 holes in the pinch weld. Drilled 4 more and secured to pinch weld. But, dimensions and construction of the rail is very precise. Any upward pressure on the rail will push the whole rail length onto the chassis without bending the pinch weld. Due to the rail construction, side impact will not bend the rail, unless impact is very severe that should not happen in "normal" off road use.
  10. The Following User Says Thank You to skala For This Useful Post:
  11. #29
    Mar 2009
    Fishhoek
    Thanked: 157
    Latest updates. Had repair done on left side exhaust manifold. Studs broke off during cats removal. So new gasket, skim manifold and new studs.
    Then fitted the Old Man Emu suspension, with air bags inside rear coils. Before and after pics below.
ID:	607474   Click image for larger version.
  12. The Following User Says Thank You to skala For This Useful Post:
  13. #30
    Mar 2009
    Fishhoek
    Thanked: 157
    And the right hand manifold broke 2 studs and developed small crack. Crack welded up and studs plus gasket replaced, all well.
  14. #31
    Mar 2009
    Fishhoek
    Thanked: 157
    Went to Trekoskraal for the day.
ID:	611063   Click image for larger version.
  15. #32
    Thanked: 3829
    Quote Originally Posted by skala View Post
    Nice level stance.
    A WK, XJ and a Ducati...
  16. The Following 2 Users Say Thank You to Rainier Vermaak For This Useful Post:
  17. #33
    Thanked: 3859
    Quote Originally Posted by Leonve View Post
    Please educate me: what is the difference between the Hemi V8 and a normal/standard V8?
    It is a type of combustion chamber. Introduced by Dodge in 1953. Hemi is the short for hemispherical combustion chamber.
  18. The Following User Says Thank You to grips For This Useful Post:
  19. #34
    Mar 2009
    Fishhoek
    Thanked: 157
    Upgrade. The 5 speed gear box is now a 6 speed box. Used HP Tuners to activate 2 Prime which effectively added an additional gear. It also shows up in the EVIC message box. The rpm at 120km/h is also about 100rpm lower.
    Will see what is does to fuel usage.
  20. The Following User Says Thank You to skala For This Useful Post:
  21. #35
    JHB
    Thanked: 62
    Which gearbox is it?
    Baa Baa Black Jeep
    2004 WJ Jeep 4.7 HO Overland
  22. #36
    Mar 2009
    Fishhoek
    Thanked: 157
    Ren, a 545RFE box. But must have the NGC4 ECM controller. That is where the software change is made using the HP Tuner.
  23. #37
    JHB
    Thanked: 62
    Thanks, have the same GB but definitely not the ECM
    Baa Baa Black Jeep
  24. #38
    May 2012
    Burning with desire! pls share more, how much was the tuning?
    pls post your fuel consumption.
  25. #39
    Mar 2009
    Fishhoek
    Thanked: 157
    Well, back in Cape after about 2100km trip that included Pakhuispas and Botterkloof pas going up and back. Must say, this extra gear is very useful in kickdown and overtaking. It actually puts another gear between 2nd and 3rd, but does not reduce rpm in D.
    With the tune I have now, I constantly get over 7km/l, mostly about 7.6; but stay under 130km/h.
    Will see what the city driving will give.
  26. #40
    Mar 2009
    Fishhoek
    Thanked: 157
    Exhaust manifold leaks!! Left side repaired mid Feb; 4 broken studs. Right side repaired beginning March; 4 studs broken.
    On returning from latest trip, I was sure than I could hear manifolds leaking slightly. Well took Jeep back to indy who did repairs. Found both sides again with leaks. Got Jeep back today. Did re-skim of manifolds, again new gaskets.
    Fault, some bolts came loose, because correct tightening procedure was not followed for the Eagle Head motor. The owner explained that he is sure his mechanics took short cuts since they never had comebacks on this before. I know him and get on well with him. No cost charged and no angry words.
    Will give feedback on the "fix".
    I noticed with the log recordings with HP Tuners that the fuel trims showed a problem. Will monitor.
    Now new task; replace whining power steer pump and flush the system. Next week.
  27. The Following User Says Thank You to skala For This Useful Post:
