Results 1 to 17 of 17
    Jan 2016
    Weltevreden Park
    Default 2013 132kw Amarok manual "Clutch slipping"
    Howzit
    Really hoping i can get some help with my issue.
    Car runs perfect when cold with no issues. If the car has been on the open road for around 20kms or so the "clutch"starts to play up.
    no matter how hot the car is 1st and 2nd have no issues what so ever from pulling off with a load or no load, you can floor it all is good.
    3rd to 6th - if you put your foot flat the car just revs and the gear you are in on the dashboard vanishes, you need to back off the accelerator then it goes back to normal.
    This is also not an everyday occurrence which makes it even stranger.
    I have been told its the clutch then told not the clutch but the auto handbrake system?
    I hope i make sense?
    Appreciate any advice
    Thank you
    May 2011
    Thanked: 1081
    Default Re: 2013 132kw Amarok manual "Clutch slipping"
    Have you had it scanned to see if it has logged any faults?
    Hillcrest
    Thanked: 21552
    The clue is in your thread title.
    NAGOF
    HAM Callsign - ZS5KAD
    Freedom of speech is useless unless you allow people you don’t like to say things you don’t like………
    Thanked: 20097
    You are very wise.
    Thanked: 3308
    How many miles on the wagon? Sounds like fluffy is right to me. I bought a kit not long ago from Goldwagen, it was around 13k from memory and then had ZF install it. Probably another 2-3k? I believe one of the guys WillemT has just done a youtube vid on the exercise.
    I took at look at the size of the gearbox and t_case and decided to leave it alone. You have to drop the front engine guard plates and then work from there, but it looks tricky without a lift and gearbox jack.
    Jan 2016
    Weltevreden Park
    Quote Originally Posted by Howie-WP View Post
    Howzit
    Yes didnt pick up anything
    Jan 2016
    Weltevreden Park
    cool thank you, don't mind ding the clutch just don't want to drop the loot and they say "oh and this and this is wrong"
    Thank you
  8. The Following User Says Thank You to Kevstar301 For This Useful Post:
    Jan 2016
    Weltevreden Park
    van has 168k on the clock
    Thanks for this appreciate the feedback
    Thanked: 20097
    Quote Originally Posted by Kevstar301 View Post
    Howzit
    an ECU can't pick up a clutch failure
    Dec 2011
    Thanked: 3645
    Long shot.....
    Water or air in the clutch hydraulics causing the it to expand and slightly disengage the clutch?
    This may be possible if the default rest position of the clutch master is not indexed correctly.
    Easy and cheap to bleed as a test.
    1993 3.0 V6 Pajero - SOLD : 2001 3.2 Di-D Pajero - SOLD
    2005 Touareg R5 2.5 TDi - SOLD : 2007 Pajero LWB 3.2 Di-D
    My YouTube channel
    Touareg Manuals Google Drive Folder : Pajero Manuals Google Drive Folder
    The clever ones are being outbred & overruled by the not so clever ones. Pair that with unchecked selfishness. We are heading for a fall!
  12. The Following User Says Thank You to MariusFourie For This Useful Post:
  13. #11
    Thanked: 3308
    Long shot.....
    Have you bled an amarock clutch? They are the devils own work. Mine was not 100% when I went to fetch mine from ZF and they were batteling with the bleeding. I had to fetch my son, so I told them to leave it and I would sort it at home. Boy you need arms like some sort of cartoon character to reach up there and get a spanner in the right spot.
    Not impossible, by a long shot, but defiantly not easy either.
  14. #12
    Dec 2011
    Thanked: 3645
    Ive invested in a vacuum bleeder. Should have done it years ago.
    My YouTube channel
  15. #13
    Sep 2013
    Thanked: 35
    Howzit
    Thank you
    Very interesting.
    Mine does exactly the same, but only in 3rd gear and intermittently.
    Keen to see if you find a solution to this.
    Oh, and I also have intermittent shudder on pull away.
    2013 132kw.
  16. #14
    Jan 2016
    Weltevreden Park
    Howzit
    Thank you
    Worth checking first
    Long shot.....
  17. #15
    Jan 2016
    Weltevreden Park
    I will let you know when i come right for sure
    Quote Originally Posted by Ivtec View Post
    Very interesting.
    2013 132kw.
  18. The Following User Says Thank You to Kevstar301 For This Useful Post:
  19. #16
    Thanked: 3308
    Very interesting.
    2013 132kw.
    Thats probably the dual mass flywheel on the way out. You will not realise how bad it is until you do the clutch and flywheel and see how much better it is.
  20. The Following User Says Thank You to stephenplumb For This Useful Post:
  21. #17
    Jan 2016
    Weltevreden Park
    Howzit,
    So had a mate of mine who's a top mobile mechanic have a look at the issue. Seems like my crank seal is leaking and its possible its contaminated the friction surface of the clutch cause it to slip when hot.
    So new clutch it is
    Thanks for all the comments
  22. The Following 2 Users Say Thank You to Kevstar301 For This Useful Post:
